Results 1 to 10 of 18
Thread: would you recommed patern parts or genuine
    Regular Member veclee's Avatar
    Nov 2012
    skegness
    Vehicle : vectra c
    Trim : club
    Engine : 1800
    Mileage : 63000
    Default would you recommed patern parts or genuine
    would you recommend pattern parts or go for the genuine stuff the firm i work for has a parts account at the local motor spares place so i get it cheaper than normal and pay no vat but would i be better getting genuine vx parts the reason i ask this is i need rear upper arms and thermostat inc housing these appear to be common faults ive already done just stat but no real joy still takes ages but does get hotter
    Engine : 1.9 CDTi
    Depends on the part.
    Aftermarket stuff can be ok but its down to who makes it.
    Just tonight I priced up a set of discs and pads. Vauxhall were £130, Pagid (Top quality aftermarket) were £90 then 2 other makes that came in about £60.
    Pagid are top quailty and £40 cheaper so went for them rather than the other 2 makes that I dont know much about.
    Feb 2011
    Selby
    Some pattern parts are just as good as the GM ones, but there are some where only GM will do. The camshaft and crank position sensors on a Z18XE for example. Thermostats are best replaced with the housing (ie how GM supply them), but if the housing isn't worn you can get away with just the stat itself. Unfortunately you won't know if the housing is worn unless you remove it from the engine...
    Regular Member HITFACTORY1403's Avatar
    Mar 2011
    NEWCASTLE UPON TYNE ( Shiremoor )
    If you can't afford the genuine parts ....
    Edd China always says , go for reconditioned originals
    before patent parts
    as they are the original spec for the job .
    Jul 2011
    UK
    Year : 06
    Don't use pattern parts there never right I've got pattern brakes and they rattle like there no tomorrow sound like there is a train going along the road
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    If its anything with bushes like wishbone arms I'd recommend genuine, but for run of the mill items like brakes and service items pattern is usually more than good enough, you normally find genuine filters are made by Mann or hengst (sp)so just ask for them, motor factors like euro's tend to carry cheap pattern and oe quality parts, but gm are usually quite competitive with their prices so it can pay to check prices first
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    Quote Originally Posted by lee gsi View Post
    genuine vx 314mm disc n pad set on trade club is less than £90.00, what were you pricing up ???
    emec#1
    Engine : 1.9 CDTi
    That was retail price on Astra SRI brakes (308mm)
    Blimey, that's the fitted price for the front brake pads and discs on my car (314mm)
    Engine : 1.9 CDTi
    Tell me about it.
    Seems stupid that the Astra 308mm kit costs more than the Vectra 314mm kit.
  1. Genuine Parts Search
    By Das in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2011, 20:01
  2. Excellent source for genuine parts!
    By John LE in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2011, 11:33
  3. Genuine GM or Pattern Parts???
    By dae36 in forum Engine & Drivetrain
    Last Post: 10th January 2010, 01:43
  4. Autovaux..genuine parts?..which service items?
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2009, 22:55
  5. Non genuine parts - Headlights
    By thegoldenbullet in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2009, 09:00
