Results 1 to 10 of 11
Thread: Vec gsi 314mm ( bonking sound when tapping the brake pedal ) HELP!!!
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Default Vec gsi 314mm ( bonking sound when tapping the brake pedal ) HELP!!!
    On my Vectra gsi fitted with standard 314mm breaks when I brake slowly there ok but it i tap the break pedal I nan hear a bang noise and feel it through the steering wheel, it's like it's a loose csliper or something it's driving me mad
    what to check first?
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Check the pad clips are in place but then remove them and make sure the pad retaining clip on the back of the outside pad is attached to the pad mine came away and made a banging noise under braking.
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    Is it a cheap pad? Or is it a GM one??
    Regular Member johnnyboy1985's Avatar
    Aug 2010
    Letchworth Hertfordshire
    I have this same problem with my redstuff pads
    birmingham
    Engine : 3200
    Cheers guys the discs and pads was changed a week before I bought it so not sure if there proper gm ones, I'm gonna buy some new pads and strip down and fit just to rule it out, cheers for the help guys I will let you know if a new set of gm pads do the trick :-)
    It should be quite easy to tell if GM pads are fitted, as the GM logo should be visible on them without having to remove them from the caliper
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    i put cheap ones in and the were clunking, changed them for GMs, sorted
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    20 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 220,240
    Mine are GM and don't clunk. But they make a horrible squealing grinding noise as I drive. I thought they needed to bed in and they did get better but in the past week they have got really noisy again.
    Sorry for the hijack. I hope you sort yours easily.
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I got same prob when i brake.
    20 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 220,240
    Mine's all the time. I might strip 'em all down again and check for pieces of grit of what have you.
    Paul
  2. For Sale: Vauxhall Insignia Brake Pedal Alloy Cover - SRI sports pedal cover
    Last Post: 20th December 2012, 21:36
  3. tapping sound
    By cutchy in forum Engine & Drivetrain
    Last Post: 22nd December 2011, 21:26
  4. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  5. more pedal travel after upgrade to 314mm
    By fuzzbomUK in forum Suspension, Wheels & Brakes
    Last Post: 7th October 2008, 13:37
