Results 1 to 10 of 11
Thread: need an aftermarket front and rear parking sensor system
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Default need an aftermarket front and rear parking sensor system
    can anybody recommend a front and rear parking sensor kit that does not cost megabucks and does not require a science degree to install?
    Its for the wifes car so i guess an 8 sensor system that has an audible buzzer is the minimum but would be interested in having the little screen to show distances can only help..
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    factory front n rear park pilot is the way to do im afraid m8,come on its not like you m8 lol
    dont like these aftermarket cheapies,can give you more grief than there worth sometimes
    Full Member Sebastian's Avatar
    Electric Heated Recaro Leather
    35 Post(s)
    Engine : 1.9 DTH
    How about this one Nige ?
    http://www.parkingdynamics.co.uk/
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    129 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    I'm inclined to think along the same lines as Andy.L on this, however, that link seems to show a very "low on labour" option
    Admin plasma's Avatar
    On the Forum
    253 Post(s)
    Engine : 150
    Mileage : 74000
    I've fitted a few gagetman rear parking sensors and have never had any problems with them, there not so hot on the front as they ideally need to be switched on/off manually.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    The euro car parts kits are very reasonable and I've not had any issues with them, they were on special last month it might be worth a phone call
    Jun 2009
    South Coast
    Quote Originally Posted by andy.l View Post
    Whilst I have the factory front and rear parking pilot fitted to my Siggnum as you know i do not really want to go to that expense for the wifes vec. I can get a kit from the bay for about 50 quid that has 4 front and 4 rear sensors plus an LED screen that shows the proximity of objects and where they are etc as well as the audible warning. Its a good price and i could probably fit it myself where as the factory retrofit option would cost a lot more and she does not have the wiring for the dash button either..
    Sodding Typical on Sea
    I would like a front sensor set up but apart from manually switching it on every time you park I can only see a manual activation outside of the OEM set up. What do others do with the front sensors?
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    If u get a parking button then use the activatiom lighy circut to turn the fronts on then wore the rears to the reverse lights :-)
    Nov 2010
    UK
    Engine : z18xe
    Year : 06
    My reverse are wired to reverse light, so activate when reverse gear is selected.
    The fronts are wired to an ignition +ve and only activate when in close proximity to something, ie- 1 meter.
    £25 off eBay about a year ago.
    Sent from my Xperia S via Forum Runner
  1. fitting aftermarket rear parking sensors , best way to get into boot?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2012, 11:08
  2. Retro Fitting Tyre Pressure Monitoring System & Front/Rear parking sensors to Vectra
    By rich05uk in forum Electrical & ICE (including SatNav)
    Last Post: 7th October 2012, 12:09
  3. Fitting aftermarket parking sensors to XP 'd rear bumper
    By 2.2 oil burner in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2012, 22:45
  4. fitting aftermarket rear parking sensors
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 9th September 2011, 19:45
