Results 1 to 10 of 15
Thread: Thermostat or temp sensor
    Regular Member vectra-man's Avatar
    Dec 2012
    basildon
    Vehicle : signum 2.2
    Default Thermostat or temp sensor
    Hi all
    i'd like to pick your brains again, my temp gauge only moves when sitting in traffic or idling will hit just over 90 then the fan cuts in, but whilst driving it doesnt register at all but the heater is lovely and hot and gets hot rather quickly in the morning am i looking at thermostat temp sensor or something else.
    Regular Member bigdan1505's Avatar
    Nov 2012
    wrexham
    Vehicle : signum
    Trim : elite
    Engine : 1.9 cdti 150
    Mileage : 129,000
    im in the same boat mate i would like to know this, mine dont move aint been in traffic yet so dont know ive seen it move very very little took the sensor out and put it in hot water and nothin happened but bridged wires across to fool it and came up with service light pluged it back in and went out but still now gauge heaters lovely tho just want a gauge lol
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    mines did the same 19cdti just replaced the thermostat and that did the trick
    Regular Member sheepish's Avatar
    Yorkshire
    If your gauge goes up in traffic and down when you start moving, you can bet on it being your thermostat. It will be stuck open letting the coolant through the radiator all the time, when you're in slow moving in traffic, the whole system will manage to heat up but as soon as you're moving and air is flowing through the radiator it will cool down and the temp gauge will drop (obviously if the thermostat was working as soon as it starts to cool, under 92 degrees (for a petrol) or whatever temp the diesels run at, the thermostat closes maintaining the correct running temp).
    Regular Member smartalec0310's Avatar
    Apr 2012
    littleport
    mine did the same ever since i had it didnt realise it was a problem till reading thro here. change the thermostat housing/thermostat (one thing) £40 off ebay easy 30min job
    newport
    i just changed my stat, got the complete housing and sensor, gets warm within a couple of mins, and stays there now, before it would drop of the scale when moving
    Jan 2012
    Darlington
    Hi
    Mine is the same on the 2.0 Sri Turbo so i changed the stat and it made no difference and as i don't know where or what the sensor is i've left it as is.
    Andy
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 138000
    Quote Originally Posted by vectra-man View Post
    Hi all
    its your thermostat its broke if you type in thermostat in the search part there are loads of threads about peoples thermostats broken including mine
    the threads start appearing when the cold weather comes
    its a common fault on the vectra c
    i had the same problem with the temp gauge not moving in the cold weather and thought it was just the gauge but as i changed the thermostat now the gauge sits on 86- 89 and the heating and fuel consumption have improved quite dramaticaly
    Nov 2012
    wrexham
    Vehicle : signum
    Trim : elite
    Mileage : 129,000
    mine started workin the otherday and now stopped again heaters are mint tho but the mpg is crap.. what should i be gettin out of a 2.2dti also the range is abit vauge on the fuel ? also the other day drivin along and the dash neidels went down and the battery light came on, pulled over to go to the shop and when i came back out
    it wouldnt start
    so i opened the bonnet and slamed it after and it started
    its happened twice now and it only happens when the temp gauge works
    when the temp works the car plays up starting and when the gauge dont the car is fine
    really weird anyone else had this problem
    is it a bad earth?
    also still cant get the xenon auto correct light off the dash where is the rear sensor placed?
    thanks in advance :-)
    North Tyneside
    I appreciate that I am responding to an old thread but having searched the forum for an answer to my thermostat problems they seem to have been covered in the various threads. I have experienced the normal warm up in traffic and the quick drop in temperature when driving on a faster road. Today I did around trip of 25 miles most of it on the A1 and averaged about 60mph. The thermostat behaved perfectly which left me baffled. Could this be a sticking thermostat? If so can it be unstuck or does it mean it requires replacing? It was replaced 2 and a half years ago when we had all that snow and it's been OK until last 2-3 months . Had it in to a local garage twice and they ran the car at idle until it reached 90 degrees and they said it was fine.. I tried to explain about the cool engine on faster roads but they said it was a common fault on Vectras. They didn't charge me anything but now I don't know what to do for the best. I have no problem replacing the thermostat if necessary but I'm not convinced it is. Very intermittent performance from the thermostat. Should I replace it or not? Any advice greatly appreciated. Thanks.
  1. Is it the temp sensor or thermostat 1.9cdti
    By bennettboy in forum Engine & Drivetrain
    Last Post: 28th October 2012, 12:45
  2. Z19DT Exhaust Temp Sensor Help... & Thermostat...
    By Vectra Adz in forum Engine & Drivetrain
    Last Post: 26th June 2012, 22:08
  3. Thermostat or temp gauge or nothing?
    By mrpoochie01 in forum Vectra C / Signum Troubleshooting
    Last Post: 25th March 2012, 12:11
  4. thermostat & temp sensor
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 16th December 2011, 12:37
  5. cant unplug my temp sensor on my thermostat
    By justin32 in forum Engine & Drivetrain
    Last Post: 10th December 2011, 16:16
vectra c intermitant fault thermostat
