Thread: Gearbox noise?
    Oct 2012
    leeds
    Default Gearbox noise?
    Hi
    I have a 1.8vvt on a 56plate with 59K on the clock.Just lately i seem to be getting quite a bit of noise when cruising in higher gears & under engine braking.It sounds like a whirring kind of noise,it does go if i press the clutch pedal in.
    Am i looking at a gearbox problem or could it be clutch related?
    Steve
    scotland
    sounds like worn planet gears in the diff mate , I had same a while back
    Regular Member scotty82's Avatar
    Mar 2012
    cannock
    Have look see if you got a hole in the bottom of the gearbox!! changed a few of these on the 1.8.
    Oct 2012
    leeds
    Thanks for the replies,can't find any holes in the gearbox & no evidence of oil leaks.Is the diff separate to the main gearbox or would it all need replacing if it is that?.
    Thanks again.
    scotland
    the diff can be replaced but just as easy to swap a gearbox , jack up the front get someone to hold one wheel and spin the other fast by hand and listen at g/box for noise.
    mine was fine on the power but soon as your of the gas it whirred like hell . changed it for a close ratio box and never looked back
    Oct 2012
    leeds
    Cheers for that,will give that a go.
  1. rattling noise from gearbox
    By daz-b in forum Engine & Drivetrain
    Last Post: 4th December 2011, 22:24
  2. Knocking Noise from gearbox
    By bettyswollocks in forum Engine & Drivetrain
    Last Post: 10th February 2010, 12:11
  3. Rattling noise from gearbox
    By mikaz in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:09
  4. Clutch/Gearbox Noise
    By scott1uk in forum Engine & Drivetrain
    Last Post: 14th November 2008, 11:03
  5. 1.8 Gearbox Noise
    By Bigboydal500 in forum Engine & Drivetrain
    Last Post: 14th November 2007, 09:56
vectra c gear noise
