Thread: EGR valve
    Dec 2012
    Norfolk
    Default EGR valve
    Recently i have got a new inlet manifold as i have had the dreaded lack of power at low revs, and on inspection the link rod for the swirl flaps was off. (I have a 1.9 CDTI 150 estate) so was a inlet manifold change as this was under warranty. This however didn't solve the problem, i have ordered a new EGR valve but when i took my one off i noticed coiled swarf on one of the bolt threads that goes in to the inlet manifold, this bolt will no longer tighten up. My question is does anybody know if this is just a wire thread insert or is the thread tapped straight in to the manifold.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Seems like the place that did the manifold under warranty had over tightened the EGR bolt - the manifold can be heli-coiled quite easily though.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Seen this happen a few times unfortunatly - as well as the boost pressure sensor bolt too.
    As Dan says - simple heli-coil and you will be fine. A possible slightly longer bolt too may work as it often only takes the thread at the start of the bolt hole
    Dec 2012
    Norfolk
    Yeh that is what i thought, do you know the best place i can get a heli coil or longer bolt from?
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
