Results 1 to 10 of 17
Thread: Car Service
    Regular Member thestaffy's Avatar
    belfast
    Default Car Service
    Hi i was wondering if 1 of you gould gide me threw a step by step service on my vectra 2.0 tdi 2003.What parts i need (the best parts for performance) where they go etc etc.Thank you
    Regular Member Paddy2bsure's Avatar
    Hertfordshire
    Quote Originally Posted by thestaffy View Post
    What mileage are you currently on, when (and at what mileage) was the car last serviced?
    Nicking Ya Dinner.
    Nice easy one that Staffy.
    Parts
    Flush for engine,injectors, Vx sell Fortron ones, expensive if you dont use trade card btw
    Pollen Filter, easy fit, just lift up the seal strip on the bulkhead and replace
    Air filter, unscrew the 5 or 6 torx, lift lid fit and replace lid.
    Oil Filter, Front right of engine as you look at it, cartridge, unscrew the top, replace both small rubber and large rubber on the stalk, push in the cart and screw back up, doesn't need to much tightning btw
    5 litres of oil, I use semi, book says full synth, but thats only if you want to run for 20k between services.
    Sump plug seal ring, always replace this one.
    Diesel Filter, alongside the header tank bottle, torx screw on top, undo and replace rubber seal again, undo screw at the bottom, allow old derv to run out, tighten up and half filll the housing with fresh derv, push the new filter in and top up the derv, replace top, get it right or it will leak.
    (you must fill the filter housing back up or you will get air in the system and it wont start btw)
    Final one is oil reconditioner, again Fortron, this goes in the new oil and protects against the flush residue that is still in the engine.
    HTH.
    Nicking Ya Dinner.
    Sump plug at the rear
    Oil Filter housing
    Diesel Filter housing
    Treatments
    Nicking Ya Dinner.
    Oh yeah, a few more pointers, the sump plug will be tight, you may need to employ the spanner over the wrench tactic to free it off.
    The electric plug on the unit next to the oil filter needs to come off for access to the filter housing, you'll see it gets in the way.
    Engine flush to be ran in a hot engine on idle for no more than 10 minutes.
    belfast
    Tell you what you guys are great
    belfast
    My oil filter is not were you say it is my car is a 2.0 dti 2003
    Nicking Ya Dinner.
    Hmmm, that picture is from a 54 2.0dti, can't imagine it's anywhere else, it's the same as my 98 2.0dti B model was.
    belfast
    Would it be underneath the car where the plastic covering is?
    Nicking Ya Dinner.
    Na, it should be where I showed you, it's the second pic down and the black unit with the 32mm nut on it.
  1. Replies: 341
    Last Post: 20th April 2016, 06:29
  2. Service book - copy of service page (2.0 DTi)?
    By mvdg in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2011, 22:48
  3. Free MOT & Service reminder service
    By norfolk in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2010, 05:59
  4. 40k mile service and service light
    By a_j_mair in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2009, 14:41
  5. is there a way to reset service light yourself after a service?
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 00:14
