Results 1 to 10 of 19
Thread: 2.0DTi starting problems
    Dec 2012
    Haverhill
    Default 2.0DTi starting problems
    Hi,
    just bought a 2004 2.0DTi
    When i start the car the glow light comes on and it starts fine.
    12 hours later after finishing work it starts fine aswel.
    But if i was to go shopping and return to the car an hour later for instance the glow lights don't come on and the car struggles a lot to start ( 3 or 4 attempts / and a lot of white smoke )
    Once the car is started if you were to turn it off and try and start it straight away it will have the same problem,
    can anybody help please?
    cheers
    dave
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Probably a starter motor fault.
    Have it checked by auto electrician.
    Nov 2012
    Birmingham
    IT sounds very much like the leak off pipes, not a starter problem.
    Mines exactly the same. When it is very cold, below 3 degrees I think, the glow plugs activate, and it starts quickly. When over that, the car struggles to start. I put my foot flat to the floor and keep doing it up and down and it starts eventually. Basically there are pipes which connect to the injectors. When the engine is switched off, they take the fuel back to the tank. What you've most likely got it splits in the rubber pipes. This is a very common fault in the DTi engines, as many other DTi owners will confirm.
    The good news is that it is a cheap job. You just buy the same rubber pipes for a tenner and replace yourself. I'm sure someone will correct any information I've got wrong and help you with what to do. I haven't done it yet so I can't help on that manner, however all your problems are identical to mine.
    A tip for you, park the car facing downwards. If you park it uphill it will be very hard to start.
    May 2011
    South London
    Nah never leak off pipes, if it starts ok from cold after being left for more than 8 hours there's fuel at the injectors not air.
    But its a cheap fix and should be done as a matter of course.
    The reason its probably the sarter is when its hot/warm the stater internals are heated up and can become slow to turnover,
    when cold the internals have contracted allowing the starter to spin more freely.
    This can work both ways as with the z19dt/h engines where the starter does the opposite, bad cold start good warm starting.
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Read my thread! I had same problem, change battery 1st then starter ;-)
    Irmscher Insignia CDTI 130
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    depends what year the car is , my 2003 dti was a right pain to start & I did my research , testing things etc .
    I found out that it would start much better when cold if the temp sensor was unplugged , so rang the dealer & found out about field remedy 1579 .
    this involves reprogramming the ECU software so that the glow plugs come on sooner & also alters the fuelling on start up.
    since having this done mine starts a lot better hot or cold .
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    Right i have the same problem and i have discovered this happens when the egr valve gets stuck open
    to check this take the grey half round cover off the egr and when this happens push hook shape bar down
    and away you go
    May 2011
    South London
    Quote Originally Posted by DTi Elite View Post
    Thats for cold starting problems.
    Op's problems warm hot starting and has the later software as its a 2004.
    Field Remedy: 1579
    Subject:Engine - Bad cold start behaviour Models:Engines:Option:Vectra-C 2002...2003Y20DTHNoneComplaint:Bad cold start behaviour especially between +5 and +9°C coolant temperature.Cause: Problem caused by Software deviation.Production : production implementation pending, details will be communicated upon availability.
    Remedy:
    In case of customer complaint reprogram with new software (decrease of cold start injection amount and modified preheat phase timing).Available with TIS-CD 40, April 2003.Functional Group:J - Engine Complaint Group:13 - No/Poor Function Trouble Code:None
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    183 Post(s)
    Trim : Design+
    Mileage : 101000
    My old astra 2.0dti (which my mother inherited when I bought the signum) was exactly like this.
    Guess how I fixed it? Another map edit :-)
    after that I learned about the field remedy. but as I already had my remapping kit my dear mother didn't have to pay the stealers a penny. I just tweaked the glow timer map.
    Nov 2012
    Birmingham
    Got home at 8pm, parked car outside. Went to start at 11pm and it doesn't start, just cranking.
    When I go to start in the morning, it'll start in one turn of the key.
    So whenever I leave the car for a few hours, it doesn't start. If I leave it overnight so it gets cold, it starts.
  1. Starting Problems 2.0DTI
    By danny1992 in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2013, 19:29
  2. 2.0dti Not Starting
    By rossgetty in forum Engine & Drivetrain
    Last Post: 27th March 2010, 20:14
  3. 2.0dti trouble starting
    Last Post: 31st January 2010, 18:58
  4. 2.0DTi Starting issues.. Really need some HELP
    By Diet1985 in forum Engine & Drivetrain
    Last Post: 6th October 2009, 10:32
  5. 2.0dti non starting
    By richc in forum Engine & Drivetrain
    Last Post: 1st June 2008, 22:01
zdt19 vectra
