Thread: Water leak in boot
    Dec 2012
    Haverhill
    Default Water leak in boot
    Hi,
    just bought a vectra 2004. The boot lining was soaking and there was a large puddle in the spare wheel well. After a few days of drying everything out and mopping up the water ive noticed that the water appears to be coming from inside the two access flaps on the side of the boot.
    If you put your hand up inside the flaps and up inside the water goes all the way up to the near the rear small windows, its wet all the way down on both side from there down to the bottom.
    does anybody have any ideas of where to start?
    thanks
    dave
    Regular Member TAB's Avatar
    Nov 2012
    Forest Town, Mansfield, Notts
    Vehicle : Vectra C VXR
    Trim : VXR Fully Loaded
    Engine : 2.8 Turbo, remapped
    Mileage : 65,000
    Iirc it could be aerial rubber seal, or rear small window seal, or possibly from rear light seal... usual culprit is aerial seal but sounds like the seals on the small windows?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    It was the aerial rubber on mine that was causing the water in the boot on mine. Replaced and leak free now.
    VIP-Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    If it is coming from that high up, then the aerial seal gets my vote. Both my Vectras have leaked for the same reason.
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Lets hope you have the small standard aerial base the dab seal is £220 from the dealers you do get a free base unit with that though
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 137000
    scotland
    its from the gutters , under the trim there is a plastic clip which is riveted to the roof , rubber washer will be perished , I just cleaned around mine and siliconed under/around it .
    Dec 2012
    Haverhill
    Hi, thanks for the advice. I will have a closer look at the things you've mentioned. If its leaking from the ariel would it make the roof line wet? Just mine is bone dry.
    cheer
    dave
    East Ayrshire
    10 Post(s)
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Quote Originally Posted by Davyturner View Post
    cheer
    dave
    Both my Vectras have had wet boots at some point due to the aerial seal being perished, and neither had a wet roof-lining. I think the water ingress is just enough to travel across the lower surface of the roof and isn't enough to actually cause a drip.
  1. Water Leak
    By Sike in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2012, 14:42
  2. What cured your water leak (hatchback, damp floor in boot/spare wheel well)
    By DNS in forum Vectra C / Signum Troubleshooting
    Last Post: 5th October 2011, 19:31
  3. Water leak in boot
    By CRAiGi-bOY in forum Bodywork & Interior
    Last Post: 10th October 2007, 10:27
  4. water leak
    By zubs187 in forum Engine & Drivetrain
    Last Post: 22nd July 2007, 18:17
vectra c aerial leak
vectra c water in boot
vauxhall insignia water leak in boot
