Results 1 to 10 of 16
Thread: Fitting interior in vectra c rounded torx bolt
    Sep 2012
    Teesside
    Exclamation Fitting interior in vectra c rounded torx bolt
    trying to fit a front seat in vectra but they torx bolts are rounded off inside, any suggestions?
    VIP-Member antowens's Avatar
    Dec 2011
    liverpool
    6 Post(s)
    did you ise the right size t50 ???
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Weld a nut onto the head? Iirc there should be enough room to do it. This seems to happen alot when folk use the wrong sized torx bit in the hole. There is thread lock on the bolts which doesn't really help matters
    Sep 2012
    Teesside
    guilty! used the wrong size at first, welding a nut? wouldn't there be a chance of burning the carpet?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    You'd have to cover everything up really well before you start (remembering to disconnect the battery) and then keep an eye on things for a few hours to make sure nothing has caught alight.
    An easy out would possibly work but due to all of the thread lock you'd probably just slip in the hole
    Regular Member fistymus's Avatar
    Sep 2012
    Saltburn-by-the-Sea
    Vehicle : 1.9CDTi (120) Estate
    Year : 55
    Mileage : 126000
    Dremel a groove into the head then use a big flatblade to undo it
    Regular Member R13hard's Avatar
    Devon
    Engine : 2.0 Turbo
    Quote Originally Posted by fistymus View Post
    This is what I did in exactly the same situation
    Dec 2011
    liverpool
    6 Post(s)
    there tight though take some.force to get them.of i used a breaker batlr in the end
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    Use an allen key on a socket, did one on my car on monday, used a T45 on a impact gun, oh how shiny bits of metal flew everywhere
    Allen key whacked in the hole fits good, then i used a breaker bar on it whilst whacking down on the allen key
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Or you could do what I did when I had exactly the same problem and just remove the runner that you did it to from the bottom of the seat, leave it in place in the car, remove the same runner on the new seat and be careful to line everything up properly when you re-fit.
    Runner still in place drivers side of drivers seat where I rounded off the bolt
    Note the missing runner on the back seat
  1. Steering Wheel bolt torx size
    By Vectra Forever in forum Bodywork & Interior
    Last Post: 18th July 2011, 22:06
  2. Torx Bolt Size - Rear Suspension Dampers
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2010, 16:51
  3. fitting leather interior to vectra c
    By vec22direct in forum Bodywork & Interior
    Last Post: 30th July 2010, 18:52
  4. Boost valve torx bolt??
    By Governor in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2010, 17:34
  5. TORX bolt size ?
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2008, 15:19
remove vectra c seats torx
