Thread: Washer motor stopped?
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    Default Washer motor stopped?
    My old man has a Zafira and says his washer motor seems to have stopped. He syas it doesn't even make a sound and it happened after a day when they didn't work as they froze up in low temperatures? Any ideas?
    Nov 2010
    East Midlands
    Trim : design
    Hi - not sure about the Zafira but believe it is similar to the Vectra - http://www.vectra-c.com/forum/showth...eenwash-filter
    Engine : 1.9 CDTi
    Check the fuse as they blow on the Corsa C when they freeze.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    as alcutler said above the same happened to me the filter gets blocked up
    try the above
    i had to get mine done the mot tester failed it on this
    Engine : Z18XE
    Cheers guys I did mention to him to check the fuse! I'll mention the blocked filter.
    11 Post(s)
    If the filter has blocked, you should still be able to hear the motor working.
  1. Heater Blower Motor suddenly stopped
    By Snizzers in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2012, 22:58
  2. Stopped the car during DPF regen.
    By dariousa in forum Engine & Drivetrain
    Last Post: 27th September 2010, 19:09
  3. heater motor has stopped.
    By Jen in forum Electrical & ICE (including SatNav)
    Last Post: 23rd February 2010, 20:23
  4. Stopped for Speeding!
    By Dodger in forum Comedy & Humour
    Last Post: 6th February 2008, 19:15
  5. Windscreen Washer Motor
    By cae2020 in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2007, 21:31
