Thread: vectra c suspension problems .
    Mar 2011
    Luton Beds
    Default vectra c suspension problems .
    Hi all i have a 53 plate 2.2dti elegance and have been more than happy with it but am looking at buying a 58/09 1.9cdti design,sri or elite and have had springs break in the past , does anyone know if GM have rectified this problem so later model vectras are spring break free! Correct me if i'm wrong but i think sri versions have stronger suspension many thanks people.
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    they break all the time on all models but its by no means a vauxhall issue its an all brands issue
    you can buy a set of after market springs that are way stronger for little money I have low sport 30mm springs
    the ride is improved theres no nose floating about heavy breaking or acceleration
    http://www.ebay.co.uk/itm/VAUXHALL-V...item2eb57aef87
    cheaper than 1 replacement spring or was when I was looking for sri ones
    Mar 2011
    Luton Beds
    Thanks for your help John surprised GM haven't fitted stronger springs on later models. Also does lowering the suspension by 30mm
    count as a modification to change insurance?
    Jun 2012
    lancashire
    its not a GM only issue all makes are having the same problems its the roads
    as for insurance being a change in car no doubt you could say you had no idea I doubt it would make much of a difference anyway
    Mar 2011
    Luton Beds
    Ok thanks again John, Blooming Speed bumps strike again !
  1. FK Coilovers suspension problems
    By craig20102010 in forum Suspension, Wheels & Brakes
    Last Post: 29th November 2012, 23:03
  2. vectra sri suspension on a 2.2, will it fit a 1.8?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2012, 13:10
  3. Suspension problems!
    By Matt_Bankier in forum Suspension, Wheels & Brakes
    Last Post: 13th April 2012, 19:42
  4. Suspension problems...part numbers
    By n8sby in forum Suspension, Wheels & Brakes
    Last Post: 10th March 2011, 13:02
  5. Rear Suspension problems?
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2007, 07:05
vauxhall vectra c suspension problems
