Results 1 to 10 of 17
Thread: xenon headlight
    Oct 2012
    wrexham
    Default xenon headlight
    if i bought xenon headlights will they plug stright in and work with no hassle
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    You'd need a tech2 session to activate the xenon feature otherwise you'll probably get bulb error messages and pulsing headlights. There are other features that'll probably be a miss like auto leveling sensing etc....
    Wirral / ellesmere port
    10 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    Quote Originally Posted by brod999 View Post
    no they wont m8
    you will need to have the add on wiring harness made and fitted along with a front and rear level sensor,rear add on
    axle wiring for the rear axle sensor then fit headlamps and a tech2 session to configure them to the car.
    easy enough to do if you know what ya doing
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    You Will have to dó something NO matter what. All depends on how much you want working as oem
    VIP-Member antowens's Avatar
    Dec 2011
    liverpool
    just get HIDs same thing less expensive
    Oct 2009
    Aberdeenshire
    they are almost the same, full factory style install, will be 100% legal, retrofit kits do have question marks over legality.
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    Quote Originally Posted by andy.l View Post
    no they wont m8
    Exactly what he said , they not just plug and play... U won't be able to connect passenger headlight as its using different connector ....,
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    Well u guys are jumping on hes looking at AFL's what if its just xenons, the Vauxhall xenons look like the normal headlights at the front like the ones u have and are slightly different at the back, where as the AFL's look different from the front and back. I dont know whether the plug for the headlight is the same for normal headlights and xenons, but as said the AFL's will be different I think they are 16 way plugs? Am I right Seb?? Where as normal headlights are 10 way. But ive not seen xenons so im not sure about one, would imagine it would be the same because its just the bulb thats ugraded and not all the fancy bi-xenon AFL extras.
    But if uve got the cash for xenons and they plug in ok go for it, either that go for HID kits usualy about 30-60 quid, it is better to enable the xenons thru the ecu via tech2 or equivilant, but if not ul need canbus safe ones or inline cancellers. For it to look OEM u would be looking for either 4.3k( which I have) or 5k's they look the closest to OEM.
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    Il post a pic later of my set up
    10 Post(s)
    Trim : elite
    Year : 2011
    it doesnt matter if you fit xenons or afls to facelift as the wiring is the same apart from afl have a few more wires than xenons but same principal they
    both have the same 16 pin plug on the passenger side and a 10pin on the drivers side.
    std halogen headlamps only have an 8 pin although they look the same theyve only got 8 working pins and 2 are just round blank holes so you cant add
    anymore wires to the std headlamp plugs
  1. Xenon Headlight Question Please
    By countduckula55 in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2011, 20:53
  2. O/S/F VXR Xenon headlight
    By glenboy in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 23rd November 2008, 23:49
  3. xenon headlight
    By ADAM123 in forum Parts for sale
    Last Post: 5th October 2008, 20:57
  4. Passenger Xenon Headlight £40
    By thegoldenbullet in forum Parts for sale
    Last Post: 15th September 2007, 15:02
auto leveling front sensor error vectra
