Thread: HELP PLEASE - Trouble codes: P1105-FA and P0105-FA
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Default HELP PLEASE - Trouble codes: P1105-FA and P0105-FA
    Hey guys,
    Need some help please.
    My Vec 2.0 DTI 2005/05 keeps randomly going into limp home mode with the spanner light coming on.
    I have read the codes off it an am getting the below:
    P1105-FA
    P0105-FA
    .....and it says something like: "Barometric Pressure not plausible with Boost Pressure".
    I have had a read on some threads, it points to Boost Sensor or vac pipes?
    Any one a little more conclusive with this??
    Thanks.
    Regular Member fistymus's Avatar
    Sep 2012
    Saltburn-by-the-Sea
    Vehicle : 1.9CDTi (120) Estate
    Year : 55
    Mileage : 126000
    I've checked via Torque & it appears to be Vac pipes / solenoid problem as in this thread:
    http://www.vectra-c.com/forum/showth...ghlight=vacuum
    Birmingham
    My car is not that engine bud, thats the CDTi in the picture, mine is the DTI 2.0. I have just cleaned the boost sensor, will try later see how it is.
    Sep 2012
    Saltburn-by-the-Sea
    Year : 55
    Mileage : 126000
    There... That's a 2.0 DTI and it's still the vac solenoid & possibly pipes
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    The first thing to do is check all of your vacuum pipe work and connectors as they perish through time this is a common problem with the dti. Also check your boost pipe from the inter cooler to your manifold for splits. This pipe expands when under pressure so the splits can be hard to find. Have someone to rev the engine when checking the boost pipe and you will see what I mean..
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    Quote Originally Posted by Vaux-Man-G View Post
    Hey guys,
    P1105-FA
    P0105-FA
    Thanks.
    http://www.vectra-c.com/forum/showth...0105-and-P1105
    Birmingham
    I cleaned the boost sensor earlier and re-fitted - touch wood it seems OK so far. Will check the pipes too tomorrow as a matter of precaution.
    Aug 2007
    Spain
    Default Fix P1105 P0105
    Hey guys,
    P1105-FA
    P0105-FA
    Thanks.
    i fix by doing this. View the jpgs
  1. 04 Signum 2.0 DTi giving P0105 and P1105
    By portreathbeach in forum Vectra C / Signum Troubleshooting
    Last Post: 11th April 2013, 18:43
  2. PLEASE HELP!! Error codes p1105 & p0105
    By signum_05 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2012, 10:16
  3. Error codes p1105 and p0105
    By signum_05 in forum Engine & Drivetrain
    Last Post: 3rd July 2012, 12:58
  4. 2 fault codes p0105 p1105 can any1 help??
    By barrymanalow87 in forum Engine & Drivetrain
    Last Post: 23rd September 2009, 09:08
  5. P1105 and P0105 Help?
    By vectra2004 in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2008, 00:30
p1105-fa vectra
Opel DTC P1105-fa
vauxhall p1105(fa)
p1105-fa
Saab DTC P1105-FA
Opel P1105(FA)
p1105
p1105 vauxhall vectra
fault code p1105 image
vectra c p1105 code
p1105 code on opel
P1105-FA vectra c
p1105fa
2003 vectra p1105
vauxhall p0105(fa)
Opel P0105(FA)
