Results 1 to 10 of 11
Thread: Safeguard check
    Regular Member VikingLammy's Avatar
    May 2012
    Woolwich
    Vehicle : Vectra Vxr
    Trim : Vxr
    Engine : 2.8 (280)
    Mileage : 59.000
    Default Safeguard check
    It got in and turned ignition on and came up with safeguard check. I assume its something to do with the alarm as it was 3 large brackets next to a stick man running. I've checked the alarm and works fine and all the doors lock and unlock fine.
    Anybody had this before? Vectra facelift estate 07
    Dec 2011
    Seaham
    Think you will find it is to do with the rear windows in the estate. I beleive they have a connection to them which sets the alarm off if they are smashed. This connection breaks and throws up the message you are getting. There are a few postings on here about how to sort it.
    May 2012
    Woolwich
    Trim : Vxr
    Engine : 2.8 (280)
    Mileage : 59.000
    Just noticed as I walked away from the car it only bleeps once when unlock/lock the car when I press it on the key.
    May 2012
    Woolwich
    Trim : Vxr
    Engine : 2.8 (280)
    Mileage : 59.000
    Do you know where the connections are? That doesn't sound good
    Dec 2011
    Seaham
    Beleive it is the connections that go onto the glass itself, they get knocked off. Try searching the forum for a fix.
    Feb 2011
    Selby
    You can simply bypass the break glass sensors, they're behind the trim panels. As said above, there are lots of posts on this subject - you'll find them with the search facility.
    Also try setting the alarm with the ultrasonics disabled (press the 'running man' button on the dash, get out, shut door and lock car). Then leave it 5 minutes and unlock it. Does it still show 'Check Safeguard'? If not - then it's likely to be the ultrasonic module rather than the break glass sensors. If you unplug the ultrasonic module (remove the interior light and you'll see the plug) then clean up the connections and plug it back in, that can often sort the problem. It did on mine.
    Quote Originally Posted by VikingLammy View Post
    The alarm shouldn't make any noises when arming/disarming. You should only get a visual sign from the indicators.
    Regular Member fistymus's Avatar
    Sep 2012
    Saltburn-by-the-Sea
    Vehicle : 1.9CDTi (120) Estate
    Year : 55
    Mileage : 126000
    Check fuse 23 in the rear fusebox too bud. Should be a 7.5amp... It can be removed if the rear glass break sensor wires fail, but will give the safeguard check error.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Not just rear windows, it comes up as error for internal alarm as in next to internal front roof light (maplight) or button to temp disable internal motion alarm or rear alarmed windows. Mine comes up cos of motion alarm sensor just next to mapreading lights.
    I recommend u check that. Unplug and check connection is not rusted as roof kend to get damp cos winter and heating makes condensation,
    Engine : 1.9 CDTi
    Quote Originally Posted by Humourbash View Post
    Do you want an alarm sensor panel?
  1. Safeguard Check.
    By Saxman in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2012, 17:43
  2. Check Safeguard
    By Tam80 in forum Engine & Drivetrain
    Last Post: 24th April 2011, 08:43
  3. Check Safeguard
    By DaveG in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2011, 22:51
  4. Check Safeguard
    By BaileySRI in forum Electrical & ICE (including SatNav)
    Last Post: 1st March 2010, 22:41
  5. Check Safeguard (Again)
    By stevem in forum Vectra C / Signum Troubleshooting
    Last Post: 6th August 2008, 19:31
