Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
Thread: HID Conversion Kits - The Cheap Con Jobs vs The Real McCoys :)
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    140 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Default HID Conversion Kits - The Cheap Con Jobs vs The Real McCoys :)
    Ok, well this is a difficult “how to” before we even start.I ask that you fully read and try to understand the points I am making beforeposting your replies.
    I'm talking about a professional quality issue so please give it a little thought if you are interested.
    Ok, HID Conversion kits !
    It seems that the majority, if not all, of these kits are produced to supply a demand from drivers without HID’s, and from drivers who are more concerned with modifying their lights and without too much thought being given as to how long their modification will work, both properly, and safely.
    The consequence of this is that there are lots of so called conversion kits available on the market but the one I saw and experienced was probably typical, and was IMO absolutely a cheap and badly constructed solution !
    As far as converting a 12v feed to supply a lamp designed to run with HID features, it was brilliant (no pun intended), but from a design point of view, the whole idea of being able to lock a “bulb” into a bulb housing designed to take a “steel” bulb plateof a couple of mm or less thickness with a replacement bulb with a plastic base approximately twice the thickness is a major flaw, even a major “con”.
    Such a fitment might align correctly, but if it doesn’t properly “lock” into place, and is only a friction fit, then the driver is going to face problems afterwards.
    AND they do not lock into place, because the base is too thick for the original locking design!
    Are all of these HID Conversion kits the same ? Do they all expect you to squash a much thicker base into a socket designed for a much thinner mounting plate ?
    I expect it is because of what the bulb design is attempting to achieve, ie a successful bulb mount which is running at a couple of thousand times the original voltage (excuse poetic licence), hence from an isolation/insulation point of view, the thickness of a plastic mount rather than a metal base.
    I cannot believe that the HID Conversion suppliers are all acting so irresponsibly, surely some have recognised that unless thebulb is locked securely into the holder, then it is likely to jump out or vibrate loose, and become in- effective ? Are ALL of the kits the same ? Or, do some of them acknowledge the need to lock the revised thickness plate in place and provide clamps, fittings even cable ties to achieve this ?
    So, you guys buying these kits, we need your help. If you are going to say that the kit you purchased for £9.99 is the “dog’s danglies” you need to understand that a friction fit which is the type I worked on last weekend is no solution, in fact, it is likely to be the source of ongoing problems.
    Tell us about those kits that provide a proper or modified way of actually locking the bulbs in place in the headlamp mount. “We” are not really interested in the kits that rely on you bodging your headlamp to fit thenew bulbs, BUT we want you to tell us about those kits that genuinely are ,plug and play ? Do such genuine Chinese or otherwise HID conversion kits exist ?
    If so, then I would suggest that as a forum, we promote the well designed & built kits and actively discourage the purchase of the cheap n cheerful ones that will probably cause us to keep looking at the installation and “fixing” it.
    There MUST be decent and well designed full conversions for bulb to HID out there guys, so tell us which is which, and give us all a chance to avoid the conmen J
    Sodding Typical on Sea
    The kit I have fitted and have been running for over two years, came from HID's direct, the bulbs were 6000K then changed to 4300K then changed to 5000K all came with plastic bases.
    Since fitting apart from self inflicted changes, nothing has required attention. The plastic base fits equally as well as the metal base and has never become dislodged. I would add that immediately prior to the HID's I fited a pair of H7 6000K filament bulbs that came with a metal base and due to access to the area I did manage to install one of the bulbs in-correctly causing much annoyance as the beam pattern was replaced by a splodge of light.
    I agree that there are some very poor quality kits out there however and that I may well be very fortunate but can't see how this can be improved in the current supply and demand market in which we live.
    As for the safety improvement seen by fitting a kit, as I drive a large number of miles each year on unlit roads.
    If it were possible to buy a higher quality kit, I would do so but on ebay as we all know, more pounds spent doesn't guarantee better end quality products.
    Just my experience and a response to your comments.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    My kit came from HIDS-Direct, the bulbs have metal bases with the correct "tang" on them so they only fit one way round, fit correctly into the holders in the same way normal bulbs do and lock into place using the standard bulb fitting in the headlight. Had they been any different to that, they'd have been sent back...
    8 Post(s)
    I bought my HID kit from www.hids4us.com over 3 years ago for something like £67 (they're a bit cheaper now). Worked straight out the box with no issues. Plastic base HID bulbs clipped into my facelift headlights without any dramas. They have never become dislodged through vibration, etc.
    I had to replace a blown HID bulb approx 2 years 5 months later and that's the first time they became detached from the headlight. The replacements also have plastic bases and have been clipped in place for nearly 12 months now. cost approx £10 for the 2 bulbs.
    In short, no issues whatsoever with plastic based HIDs bulbs.
    Engine : 1.9 CDTi
    Had a £30 set on this car for 3 years and before that it was on another car for 2 years.
    As for the metal or plastic base argument aslong as they are secure it doesn't matter as the length on the bulb from the base be it metal or plastic will (Should) be the same. You could have a base 3 miles thick but the length of the bulb protruding (And being focused) would be the same.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    To the OP, who is the royal "we" to which you refer to in the post?
    VIP-Member antowens's Avatar
    Dec 2011
    liverpool
    me hahaha i didnt think it was that bad but i agree with the bulbs surely they should clip in securely but mine havent budged and am happy with them
    Lancashire
    Trim : XP1
    Mileage : 66000
    Suppose I should add that all the HiD kits I have had have had plastic bases, and never budged at all (in a cumulative 6+ year period).
    Dec 2011
    liverpool
    well mine havent moved so far and i dont think they will but as said there is a difference in thickness between the metal base and plastic based ones but as i said i am happy so far and i didnt know anything about this hahaha
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
  1. Dual Mass To Solid Flywheel Conversion Kits
    By sloper in forum Diesel Engine related
    Last Post: 4th March 2012, 14:41
  2. HID Xenon Conversion Kits
    By kevinmc in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2012, 00:44
  3. Dash conversion kits
    By Derek Mc in forum Styling
    Last Post: 14th November 2010, 19:00
  4. HID Conversion Kits
    By topman in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2008, 20:24
