Thread: Adding new devices (sharing) a fuse - Advice please - Including how to dis-assemble
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    178 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Default Adding new devices (sharing) a fuse - Advice please - Including how to dis-assemble
    Hi Guys. I just wondered what was the best way to add a new device to the existing fuseboard wiring - I am looking at the main board near the battery under the bonnet.
    Firstly (apart from disconnecting the battery first) is this easily dismantled to get to the existing wired connections, and if so, is there a "how to" anywhere ?
    I've tried the obvious removal of the existing (from memory) 5-6 torx bolts, but the top plate didn't want to budge and so I left it alone and reassembled it. Was I approaching this from the wrong angle ? Is it fairly easy to add a new device wire underneath the fuses ?
    Or, is it best done with a piggy-back fuseholder ? If so, does anyone know what the physical size/measurement of the smaller fuses is, and where to get a piggy-back connector for that size of small fuse ?
    I was intending to use the switched supply at fuse 10 but whilst I could obviously add a fuse, I couldn't attach a wire.
    So, is there some "best practise" advice ?
    I am aware that inadequate care could lead to "self destruction" of the car LOL
    Woody
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Quote Originally Posted by woodpeck View Post
    Yes. I wouldnt go adding things to the underside of the existing fusebox, unless its the specific thing for that slot, headlight washers, level sensor etc, its all PCB's and modules. Or run a dedicated wire with a fuse direct from the battery which is what I would suggest.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    What is it your trying to run mate?
    May 2012
    178 Post(s)
    Mileage : 131,000
    Quote Originally Posted by Critch View Post
    A "ham" Radio Critch
    May 2012
    178 Post(s)
    Mileage : 131,000
    I was only going to use the fuseboard ignition switched connector to power a relay to isolate everything Critch.
    Ok, well the unanswered question , I will probably ue a piggy back fuse holder to solve my problem, the question is, are the small fuses in the underhood fusebox classed as "mini", or are they classed as "micro", or are they a special GM type ?
    Thanks for the answers guys
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    think that depends on the fuse box you want to use
    I wouldnt over complicate things the vec has good suppressors just run it off the battery
    if you want it to power off when you turn off the ignition then run off the cig lighter socket its easy to get behind it and will run 10amp
    May 2012
    178 Post(s)
    Mileage : 131,000
    I'm not going to over-complicate things. TBH a piggyback fuse connection to the existing under bonnet fusebox, is probably the easiest of all options to use. I'll run the power (fused) direct from the battery, just switch it via a relay powered by fuse 10 so that it is ignition controlled. I just need to know if the Vectra fuses are classed as either mini, micro, or something else
    Jun 2012
    lancashire
    take your relay feed from the cig lighter plenty of room to hide it in there and save messing with the fuse box
    but if your not pulling more than 10 amp I dont see what you would gain
    May 2012
    178 Post(s)
    Mileage : 131,000
    No, sorry John, I want an installation that I can just "pull" easily, with the minimum amount of cable ( I reckon a piggyback fuseholder will let me do what I need with around 6" of cable). I just need to know if the fuses are mini or micro.
    Oh well, I guess for the sake of £1 odd, I'll just have to order 1 of each to try LOL.
  1. Airsofters assemble!
    By mickydoos in forum The 'Off Topic' room
    Last Post: 5th July 2012, 20:27
  2. switched fuse advice
    By wildchild in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2012, 14:32
  3. HELP! : Interior Light Switch re assemble problem
    By Envy in forum Vectra C / Signum Troubleshooting
    Last Post: 18th September 2011, 19:54
  4. The sharing marriage
    By Gaz the Cab in forum Comedy & Humour
    Last Post: 26th January 2008, 20:23
  5. Replies: 7
    Last Post: 22nd May 2007, 23:14
