Thread: Can some one help me?
    Regular Member shb1988's Avatar
    Oct 2010
    sittingbourne
    2 Thread(s)
    Default Can some one help me?
    I found an exhaust flexi on eBay which is genuine Vauxhall part and it had this part number 55185819. Now I've looked it up and it says for the 1.9cdti and a few returns have been for the 8v which I have, but it looks like it bolts onto something at both ends, one end goes to the pre cat but the other end would only go to the dpf I assume? I'm hoping the image isn't of the actual part as I don't have a dpf
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    think the cars without the DPF it would bolt to the CAT which is roughly in the same place as the DPF would be.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Oct 2010
    sittingbourne
    2 Thread(s)
    Just been out and jacked mine up and my flexi is part of the cat, has a bit of pipe between the flexi and cat but the flexi doesn't come apart from the cat so thinking it may be the wrong part
    Oct 2010
    sittingbourne
    2 Thread(s)
    He has finally messaged and it doesn't have the cat so is for models with dpf so won't be getting it
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    your flexi on the way out? if so buy just the flexi and get the old one cut out and new one welded in.
    Oct 2010
    sittingbourne
    2 Thread(s)
    Yeah will do that, mine got flagged up on the mot as slight blow from flexi. Was told is still fine to use but just keep an eye on it for future mot
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    Pipe, assy., exhaust, front (used with exhaust system particle filter)15518581958 54 235z03
    Oct 2010
    sittingbourne
    2 Thread(s)
    Yeah so is definitely the wrong bit, he is refunding me minus delivery cost as apparently he has already paid it.
