Results 1 to 2 of 2
Thread: gearbox help
    Dec 2012
    aucterarder
    confused gearbox help
    i have a 1.8 with a f17 wide ratio box with a 3.94 ratio,problem being it has a hole in it,looks like bearing failure,question is,i have a f13 close ratio box sitting here with no probs,now would it be ok to use it in my car,thanks
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Will probably over rev and run like crap if the ratios not right.
    Check on the gearbox end plate for the final drive ratios they are stamped by hand usually you need to match that up with the F13/F17 boxes.
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Gearbox and Gearbox Oil question
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2011, 17:01
