Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Facelift Angel Eyes & LED Issues Questions...
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Default Facelift Angel Eyes & LED Issues Questions...
    Right, I've decided I will be getting some Angel Eyes for my facelift after Christmas, but fancy getting some LED's in them while I fit them. I do have a few questions regarding the fitting of these;
    • I believe the motors from my existing lights need to be transferred over, is this a difficult job?
    • What LED's do I need for the Halo's (one's that won't bring a dash error), and how many?
    • Are these easy to fit, presume they are with the lights out?
    • What indicator bulbs are they, are they the same, i.e. offset pin ones?
    I know (with the right LED's) I won't get a dash error, but what exactly happens with the strobing? I assume when they are on, there is no issues, but when they are off the flicker/strobe as the Canbus checks the system, but how long do they do it when the car is switched off?
    Sorry for all the questions, I just want to make sure I can do the job in one go, cheers
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Yes, No
    http://www.wardenjp.com/stores/2474.html You need 16
    Yes, but fiddly and yes
    Yes
    Nov 2010
    UK
    Engine : z18xe
    Year : 06
    [*]I believe the motors from my existing lights need to be transferred over, is this a difficult job?[*]What LED's do I need for the Halo's (one's that won't bring a dash error), and how many?[*]Are these easy to fit, presume they are with the lights out?[*]What indicator bulbs are they, are they the same, i.e. offset pin ones?
    Yes, you will need to keep your motors, easy to do!
    Don't know how to link to the triple head led's, but you will need a load resistor to stop the error message, they will strobe regardless of this being fitted when switched off.
    Easier to do out of the car.
    Indicators are the same. :-)
    Sent from my Xperia S via Forum Runner
    Nov 2010
    UK
    Engine : z18xe
    Year : 06
    Ahh beaten to it by a pro lol!
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I cant remember but sure Ian will let you know but im sure the leds give a error unless you get a canceller i think that's what its called Ian will correct me
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    You can always do what i did and it stopped strobbing and the error.
    Wire the leds up so they come on with the ignition and add the bulb holders for normal bulbs to the main head light wires.
    Nov 2010
    UK
    Engine : z18xe
    Year : 06
    Quote Originally Posted by Mark-R View Post
    Going to wire mine up to the dash illumination circuit, same as the led's in my fogs.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I wired mine right into the front fuse box.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Cheers guys, much appreciated
    The re-wiring is a bit OTT for my electronic skills, but will get these LED's ready Presume those linked won't trigger the on board errors?
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Yip they do you need the resistors to stop the error i did add them but the strobbing did my head in as they strobe when your driving unless to turn your side lights on when you drive.
    wiring it up the way i did it was easer than fitting the new leds lol
  1. Facelift Angel Eyes
    By boodoo warrior in forum Styling
    Last Post: 3rd December 2012, 01:39
  2. Facelift Angel Eyes???
    By ScubaSteve in forum Styling
    Last Post: 21st April 2009, 21:07
  3. Facelift angel eyes
    By jasone in forum Styling
    Last Post: 2nd August 2008, 09:23
fancy led headlights for vectra c facelift
