Results 1 to 1 of 1
Thread: Turbo Spool with a 56mm Hybrid
    South Central England
    12 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Post Turbo Spool with a 56mm Hybrid
    As per the title, here is a graph generated using the OPCOM data log from my current turbo. I have reduced water/methanol quantity down to 0.4 ltr/min from my normal 0.8 because the over boost was too aggessive on the current map and I have requested a slight reduction in VNT around there. One I get my controller back I'll be able to modify the flow to reduce it there too but I have lent it out for a few weeks, leaving me with only pressure activation.
    This is fith gear as stated to keep under the speed limit Sixth would spool a little earlier, even more so with the full amount of water/methanol running.
    Going to plonk it on the rollers down in Fareham to see what it is doing now. I expect les bhp then the last run with a much bigger compressor but alot more torque than the poor 350lbft it reached over at above 3000rpm.
    Barametric pressure on the day was vertually bang on 100 but the readings on the graph are absolute, so 300 is about 2bar above atmospheric here (29psi).
    The bottom axis is just time
  1. turbo spool
    By marc vectra sri in forum Engine & Drivetrain
    Last Post: 21st March 2012, 01:28
  2. Turbo Technics Hybrid turbo details.
    By nutron in forum Diesel Engine related
    Last Post: 28th February 2011, 22:57
  3. Vectra 1.9 CDTI, cannot hear turbo spool up
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2010, 11:43
  4. turbo spool
    By Dougb in forum Engine & Drivetrain
    Last Post: 5th May 2010, 09:27
  5. Restricting EGR flow may help turbo spool up 1.9 DTH
    By Chocki in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2010, 13:32
