Thread: another new fault
    Regular Member vecsxi's Avatar
    Nov 2005
    liverpool
    Default another new fault
    The list of faults continues to grow as for the past few days after cold starting there is no power at all as if the turbo isnt kicking in. If i stop and restart the engine the power returns god knows whats causing this one lol
    Nov 2005
    liverpool
    Fault update. It is not just related to cold starting, can happen at any time. Also restarting doesnt always clear the fault and when its faulting it wont rev past 3200 RPM. EGR has been disconnected for a while as was causing car to pull away sluggishly from lights. Anybody come across anything like this before? HELP !!!!!!!!!
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Any lights? Fault codes? With the window open can you hear the turbo spooling up?
    Nov 2005
    liverpool
    mil light is on permantly beacuse of egr, cant hear turbo spooling up at all.
    Jan 2012
    Milton keynes
    Mileage : 38100
    Do you have a code reader? Probably the best £20 investment you'll ever make... not just for a Vxl.
    Regular Member fistymus's Avatar
    Sep 2012
    Saltburn-by-the-Sea
    Vehicle : 1.9CDTi (120) Estate
    Year : 55
    Mileage : 126000
    http://www.ebay.co.uk/itm/1709407235...84.m1497.l2649
    The one I bought works sweet as a nut with both my Samsung devices.
    Does it happen when hoofing it (check boost pipes) or at any time?
    Nov 2005
    liverpool
    happens at any time and will only rev to about 3000rpm, but sounds like its working hard at those revs. Ive noticed its now taking more restarts to return to normal, but when it does it goes like a train.
    Nov 2005
    liverpool
    Finally fixed. Traced fault to throttle body and after stripping down found electrical part to be swimming in oil. Cleaned throttle body and egr in works oil bath blast of contact spray reassemble and it now drives like a dream. Didnt suspect throttle body at first but it started making a whining noise. How it filled with oil ill never know. Thanks for everybodys help and comments on this one
  1. Not sure if this a fault or not.............
    By carperjake in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2012, 20:39
  2. Replies: 15
    Last Post: 9th July 2011, 22:19
  3. ABS fault...
    By DNS in forum Suspension, Wheels & Brakes
    Last Post: 23rd June 2011, 03:05
  4. Another Fault
    By khile in forum Vectra C / Signum Troubleshooting
    Last Post: 20th March 2010, 18:57
  5. swirl valve fault or egr valve fault
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2008, 09:04
