Thread: Auto dim mirror question
    East Midlands - Regional Organiser new boy's Avatar
    Nov 2010
    lincs
    80 Post(s)
    Vehicle : Design
    Trim : SRI LEATHER
    Engine : 1.9 cdti
    Year : 56
    Default Auto dim mirror question
    Looking at getting an auto dim mirror but can it be put in/working with out roof wiring? does it need tec2?
    South West
    You need to run a ribbon cable from the connector panel in the boot under the roof lining to the mirror in order for it to work.
    The mirror fitted without the cable will not auto dim without the connection as far as i am aware.
    Regular Member Niall83's Avatar
    Nov 2009
    Belfast
    There is a how 2 on here that connects the mirror to a live feed at the roof lights. It just need power to work. Tech2 tells the car it's there so it deactivates it when in reverse.
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    the ribbon cable contains 5 connections in it and 2 of them are so you can fit the drivers side auto dim which works at same time
    as the interior dim mirror so if you want it like as if it was factory fit then you will have to have it wired the same
    providing you already have the wiring present from the door mirror right back to the rear rec for the drivers auto dim mirror,if not then
    again this wiring will have to be added.
    fairly simple if you know wot ya doin
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Well I suppose you could wire it up without the roof loom, but tbh its going to be a ton more work. An no it doesnt need tech2 to activate it, its one of the few things that works without activation.
    Nov 2010
    lincs
    80 Post(s)
    Vehicle : Design
    Trim : SRI LEATHER
    Engine : 1.9 cdti
    Year : 56
    So i need to check if i have the wiring if not need that with the mirror. thanks guys
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    to make it work correctly you need to have it activated, that way if you put it in reverse it will clear straight away if this does not bother you then it will work plugged straight in
  1. Auto dim mirror question
    By bensterzback in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2012, 19:52
  2. Interior auto dimming mirror question
    By Mikey4996 in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2012, 18:31
  3. Help needed - Auto dim mirror & poss auto wipers
    By mark_647 in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 01:09
  4. Another auto folding mirror question
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2009, 12:36
  5. Auto wipers.. and auto dimming mirror ?
    Last Post: 28th January 2009, 01:24
