Results 1 to 10 of 24
Thread: Z22se Intermitent fault engine keeps missing and holding back
    Regular Member Telboy's Avatar
    Apr 2006
    Leeds
    Default Z22se Intermitent fault engine keeps missing and holding back
    Well after cleaning my throttle body due to slight issues of the tickover dropping and car missing a beat ever so slightly I got my code reader out and it showed faults P1120 and P1220 which is the throttle position sensor if Im right.I cleared the codes and let it see if it throws it up again. Now when I stop at any point with the car the tickover drops down to its normal 700rpm then for a split second every now and then the car seems to cut out as if its going to stop then settles itself down again. Also when you come of the throttle in traffic and come onto the throttle very slightly theres a little misfire for a very split second. Yesterday on a run to Manchester the car would not pull right and was holding back really bad as if it was missing then all of a sudden it would come into life and pull away,at this point my EML light came on so I put the fault code reader on expecting the same codes but its showing P0131 now.I cleared it off and reset the light and the car is ok again now but Im sure the fault will come again as it has before. Can anyone shed some light into what needs changing please
    Apr 2006
    Leeds
    Bump
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I cant comment on the first two codes but while reading your thread, the first thing that came to mind was a thread by Vid and his old 2.2. His car would do the same thing after he had some custom exhaust and sports manifold fitted. It turned out to be a faulty O2 sensor. Then later in your thread you mention p0131 (Oxygen O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1) so looking good so far. The 2.2 only has one bank but two sensors, one before the Cat and one after. I believe Sensor 1 is before the cat and if i remember rightly its on top of the Manifold when you look over the top of the engine.
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    What's sensor voltage?
    Vehicle : SRi
    Mileage : 137000
    Just noticed you sent me a PM, sorry my PM box is massively over full until I renew my full membership so I cant use PM until then, sorry bud.
    Apr 2006
    Leeds
    how can I check sensors voltage.
    Apr 2006
    Leeds
    Where abouts in Leeds are you and could you have a look at all If poss could come to you?
    wirral
    39 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Should be able to see it on live data depending on what equipment your using to get codes?
    or by back probing the sensor
    Dec 2011
    Seaham
    Critch, that sounds very rude and possibly illegal......
    And I am talking about a bit of "back probing"
  1. Update on intermitent fault
    By Telboy in forum Engine & Drivetrain
    Last Post: 8th January 2013, 22:05
  2. Holding back
    By obews in forum Engine & Drivetrain
    Last Post: 29th December 2012, 10:22
  3. Intermitent & Normal Speed wipers not working, Some help establishing fault plz??
    By MK SRIVECTRA in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2012, 11:51
  4. Engine holding back
    By paul4400 in forum Engine & Drivetrain
    Last Post: 6th June 2011, 00:40
  5. Another holding back thread, but at 2200 rpm
    By Gazza36 in forum Engine & Drivetrain
    Last Post: 17th June 2010, 20:53
z22se running rich
z22se holding back
vectra missing at speed z22se
vectra missing fault
