Thread: passenger airbag
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    Default passenger airbag
    hi guys read a few post on this but none give me the answer i need, as u may know the car uses a transponder in the seat, but being my car which has ****** all extra wiring and features so i doupt it will have the recivers in the seat, so im asking if i can put a switch in, surely the transponder reciver is a on or off, so i just need a switch to make the circut, if that makes sense.
    anyone know where these would be wired etc?
    cheers
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    So you want to turn passenger airbag off?
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    yeah but only if theres a car seat in it a cant be bothered to turn it on and off from tech 2 all the time. i just need to know where the wirning is for it or where it gose so i can wire in a switch.
    11 Post(s)
    Quote Originally Posted by rozzer2006 View Post
    If it were that simple, then I'm sure someone on here would have done it by now.
    Put baby in the back out of harms way.
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    The airbag system will have a fault and you will have warning lamps the receiver or transponder is designed to talk to the airbag ecu. You might potentially cause the airbag system to fail if you had an accident. There is also 2 circuits to disable the violet and the yellow one. You also have pre tensioners on the front seat belts as well. What about the airbags in the side of the seat and of you have them like I do the upper side curtain airbag. A lot to consider bud probably easier in the back seat.
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    168 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Don't mess with the complex safety / airbag system m8. Stick baby in the back, or get A Main Vx Dealership Franchisee to supply and retrofit, if indeed that is an option.
    Jun 2006
    St. Helens,Merseyside
    stolen from migweb
    The following is the advice the dealer obtained from Vauxhall Tech, relayed to me on the phone. I can make no claim as to it's accuracy as I didn't speak directly to Vauxhall Tech myself, but have no reason to doubt it as I'm sure they'd do chargeable work if they could!
    The front passenger airbag cannot be physically removed nor can it be programmed out individually with tech 2 - they declined to say if this was a technical limitation or a liability issue. When I enquired about retrofitting the front seat occupancy detection system for use with a Vauxhall child seat I was told that; 1. It would be too costly (£2k +) and 2. They wouldn't do it anyway for liability reasons. So if the vehicle does not have the ability to detect a transponder equipped child seat then no rear facing seat of any kind may be fitted in the front passenger seat.
    I asked would they disable the passenger airbag system if I were to sign a disclaimer, in the same way as VW dealers are happy to. The answer was no, they would not, no exceptions.
    The outcome was the dealer gave two choices:
    1. Don't use the car to carry infants.
    2. If the ability to carry infants in the front is a requirement, get a replacement vehicle with the appropriate features/options installed from the factory.
    In the case of an Astra or similar, if there is no system to disable the front airbag on the car from the factory (either by a keyswitch as found on the newest gen Astra or transponder system) then the front seat must not be used for infants - only the rear seat will be available for this purpose. Dealers will not intervene in any way to alter the vehicle to make it suitable.
    I was also warned it may be illegal to modify the safety systems on the vehicle as it could potentially invalidate the insurance.
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    thats rubbish. my f-ing CLIO had it and most of the other modern cars have it, ptretty crap if u ask me, i belive the corsa has it.
    GM uve let me down
  1. Airbag replacement - NSF (front passenger airbag)
    By Caveman_nige in forum Bodywork & Interior
    Last Post: 19th February 2011, 21:12
  2. Passenger airbag.
    By Saxman in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2010, 01:33
  3. Passenger Airbag
    By heaths in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2010, 06:41
  4. Passenger airbag
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2008, 22:30
  5. Passenger Airbag
    By Keithy in forum Bodywork & Interior
    Last Post: 4th February 2008, 13:05
