Thread: Earthing for alternator
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Earthing for alternator
    Need someone to point where the earth is for alternator please.
    Nov 2010
    East Midlands
    Trim : design
    Don't think there was a seperate one when I did my cdti 120 - although the body bolts straight onto the block I would think it gets a good earth from there provided the earthing to the engine is good
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    It's already earthed as it's bolted onto the engine.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    It's earthed through the engine block.
    You can confirm volt drop with multimeter to body of alt and engine block
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Just need to know where its bolted so i can remove, clean, rebolt giving good contact as got poor earthing to alternator. Photo will help :-)
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    The bolts that connect the alternator mechanically to the engine is the earth as said above remove the alternator bolts individually if you feel you need to clean the contact.
  1. Alternator
    By Hursty103 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd July 2011, 07:24
  2. Earthing point?
    By Keif in forum Bodywork & Interior
    Last Post: 20th February 2011, 22:33
  3. Alternator
    By johnny1983 in forum Diesel Engine related
    Last Post: 1st February 2011, 16:38
  4. alternator on way out?
    By ladyvec in forum Engine & Drivetrain
    Last Post: 23rd December 2010, 14:53
  5. Alternator ??
    By nigec in forum Engine & Drivetrain
    Last Post: 1st January 2010, 17:23
