Thread: Horrible Jerk / Rock when on and off the throttle
    Dec 2012
    Midlands
    Default Horrible Jerk / Rock when on and off the throttle
    Hi All, my Signum 1.9 CDTI 120 has had this since I bought it and its driving me mad, a garage thought it might be one of the engine mounts but changed the most likely one... no change.
    If you jump on the power quick (not floor it, just an initial press) its like a hard knock/jerk/lurch, same when you release it quickly, car phyically jerks forward or backwards.
    I know I've got a small hole in the lower intercooler hose but don't think its that (I actually taped it up to see but made no difference).
    When stationary if I lift the clutch really slowly it seems like something moves and then hits an endstop. Happens at all times, not just when using the clutch.
    I've trawelled the forum and really surprised that there's so many threads and nothing on this issue
    Hope you guys can help!!
    Regular Member Craig1985's Avatar
    harwich essex
    Worn engine mounts?? Worn driveshafts?
    Nov 2010
    East Midlands
    Trim : design
    Sounds very much like an engine mount as Craig suggested - have you tried rocking the engine backwards and forwards and side to side - to see if any movement.
    harwich essex
    I had this on my 1.9cdti. It was the engine mount by the gearbox.
    Dec 2012
    Midlands
    Hi, sorry for not getting back sooner (been my birthday weekend )
    I have had the engine mounts looked at and 1 was replaced (although there were never that confident it was the culprit). No change. Worn driveshaft is a good shout. Think that is the nexct thing to check out!
    Mar 2013
    liverpool
    Vehicle : '04 (54) vectra sri cdti 120
    Trim : sri
    Engine : z19dtl
    Mileage : 178000
    My cdti 120 vectra does this, does yours have a vibration between certain speeds when accelerating? Mine does and its the offside driveshaft inner cv joint thats worn, get under it and grab hold of the shaft between the 2 cv joints and rock it, if its got play and makes a click sound the joints worn, hope this helps
    Jan 2012
    Silverstone village
    I would look again at the engine mounts.
    Do you know which one they replaced ?
  1. we will rock you
    By neverlandandy in forum The 'Off Topic' room
    Last Post: 12th September 2009, 20:57
  2. Arrrr!Throttle my Throttle Body!
    By boze in forum Engine & Drivetrain
    Last Post: 12th September 2009, 11:15
  3. Rock Band
    By keith1983 in forum Games Room
    Last Post: 26th May 2009, 22:01
  4. Rock Band for the 360
    By Jay Kay 313 in forum Games Room
    Last Post: 8th August 2008, 14:45
  5. Rock you heart!
    By BlueRob in forum General Chat
    Last Post: 4th July 2007, 19:27
