Thread: can faulty glow plugs cause limp mode?
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default can faulty glow plugs cause limp mode?
    Hey guys,
    my car is going into limp mode for the first 10 minutes of driving when the outside temp is cold.after driving for a few mins and restarting its fine.Also if i start the car and leave it to idle it cuts out after a few seconds and will do this 3 or 4 times untill there is some heat in the engine.
    It doesnt always go into limp mode but the glow plug light will come on and stay on after its cut out untill i restart.
    Would fault plugs cause this?
    I hooked up my code reader when the spanner light/limp mode kicks in but nothing comes up
    Any help would be great
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    56 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Yes
    Irmscher Insignia CDTI 130
    Aug 2011
    Basingstoke
    Trim : SRI
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    try doing a glow plug cycle four times before you start the engine fella as this will help with the cold start.. but it does sound like you have a knackered glow plug but do yourself a favour and either buy from vx or a decent motor factor as antsss had a ebay cheapy break off in the head.. not good!!
    Aug 2011
    Basingstoke
    Trim : SRI
    ive just orderded some bosch ones from ECP which i will collecting in a bit.
    The only thing that confuses me is that when i had a single glow plug fault before(did a resistance test via multi meter and found the one) it only produced the spanner light for a few mins of driving and not the more serious problems ive got this time......unless its more than 1 thats gone this time?
  1. faulty thermostat/limp mode/spanner light
    By collyb in forum Engine & Drivetrain
    Last Post: 19th April 2011, 20:20
  2. glow plugs
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2011, 17:54
  3. Are all glow plugs for DTi the same?
    By fikse in forum Engine & Drivetrain
    Last Post: 16th December 2009, 16:16
  4. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
  5. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
om642 limp mode faulty Glow Plug
does damaged glow plugs put car into limp mode
vectra limp mode reset
vauxhall insignia limp mode reset
glow plug failure and limp mode
would glow plugs cause car with spanner vectra c
vauxhall zafira glow plug control reset
can glow plug make oil light come.on insignia
glow plug controller fault cause limp mode
can glow plugs mske my car go into limp mode
insignia limp mode reset from inside car
ambient temperature causes limp mode vectra
vauxhall insignia glow plug fault signs
can glow plugs cut engine out
insignia diesel limp mode
does glowplug cause engine cut out
zafira limp mode glow plug
glow plugs causing limp mode
vauxhall zafira can the glow plugs cause limp home
can glow plugs cause limp mode
astra diesel 2007 will.glow plugs not working make it go in to limp mode
does glow plug fault show on vectra c
if my glow plugs are faulting will my vehicle go into limp mode
