Thread: boot relaese
    Aug 2011
    Bristol
    Default boot relaese
    Always wandered this.
    My brothers wife has a Zafira which the boot wont unlock.
    My signum is the same electric lock but does work, I just want to know for future.
    Is there a fail safe if the electric lock fails and is it in the same position on other VX's?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    On the Vec there is a hole in the boot liner that allows you to insert the valve cap tool, in the petrol flap, and open it manually Dont know if this is the same on the Signum though.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Page 60 of the preface Signum Manual, it does indeed come with an emergency release.
    Emergency unlocking of tailgate frominside using vehicle key
    Insert key into lock and turn anticlockwise
    as far as it will go: tailgate is unlocked
    Aug 2011
    Bristol
    Good enough for me. Thanks
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    The micro switch tends to stick especially when its cold wet n horrible. The rubber protector can be removed and the mechanism cleaned but its a pain in the **** to get back in.
    I found over the years when it starts to stick just give a couple of sharp thumps with the side of a fist in the switch area. This will release the switch from the stuck position and the boot will then open. saves you climbing inside. It can be a right pain.
    There is a slot for the key/flat screwdriver that can be accessed from the inside of he boot.
    you will at some point need to give the switch mechanism a good clean with wd40 to stop this happening though.
  1. Wet boot
    By malcycee in forum Bodywork & Interior
    Last Post: 29th April 2012, 17:03
  2. Replies: 2
    Last Post: 21st August 2011, 11:38
