Thread: Vectra Glove Compartment bulb?
    North East
    Default Vectra Glove Compartment bulb?
    The light in the glove compartment of my vectra has stopped working. I have taken the bulb out but it looks fine. Is there a fuse for the glove compartment. I want to check this first before I go and buy a new bulb.
    Michael
    Barrow In Furness, Cumbria
    Check the connector hasn't dropped off the back. It had on mine.
    Take the glovebox out - 4 screws I think - and then lift out.
    North East
    Quote Originally Posted by Chris SRi View Post
    Ah ok, thanks for that - will have a look..
    Feb 2011
    Selby
    The light just unclips from the top of the glove compartment - slide it forward and it'll come out. Then see if the connector has come off. You need to remove the light when you remove the glove box (three screws on top, edge, two on bottom edge).
    11 Post(s)
    Quote Originally Posted by mpc View Post
    Not a conclusive test then.
    It may look fine, but chances are it's not. Either connect up to a separate 12v power supply or check for continuity across the filament with a multimeter.
  1. Lugggage compartment bulb.
    By LAZZEE RARSE in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2010, 00:18
  2. Complete glove box for Vectra C/Signum
    By merikiito in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 5th November 2008, 23:32
  3. Side/rear load compartment net for Vectra C
    By Duncan in forum Parts for sale
    Last Post: 29th November 2007, 13:09
  4. Load Compartment Net
    By leeds vectra in forum Parts for sale
    Last Post: 23rd November 2007, 18:51
why want my glove compartment light work on my vectra c
