Thread: no power steering on my 06 1.8vvt again any1 help??????
    Nov 2012
    Redcar
    Default no power steering on my 06 1.8vvt again any1 help??????
    hi all,i recentley got a 2006 1.8sri vvt vectra from drive vauxhall less than 2 months ago, nothing but problems with alot of things on it but they have been fixed all but 1 ongoing problem.the power steering stops working now and then,mainley when its cold on a morning,its had a new battery,alternator,coil pack but still the garage dont know the problem any ideas what it could be plzzzzzzzzzzz??????????????????????????????????
    ohhh and a clicking noise coming from the boot when the car is turned off
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    My friend had that... Take a look at the battery area. Theres a small block top left corner. Lift it. Is both top bolts with nuts fitted? As i noticed friend's car hadnt had one. I put top bolt a new nut on and immediately solved the steering issue!
    Might help u.
    Nov 2012
    Redcar
    Ok thanks mate il have a look
    Nov 2010
    East Midlands
    Trim : design
    Have you checked the connectors going into the power steering pump - disconnect them, clean them and reconnect - Also is your alternator ok that a classic sign of alternator problem
    Nov 2012
    Redcar
    Yeh it's had a new alternator and battery from drive as its under warranty but they don't no wot the problem is so trying to find out myself as its been in and out of the garage 6 times with the same problem,thanks
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Did u check next to battery, top left corner its covered by lid on top. Opened by front upwards, there will be most likely only one bolted down on 2 bolts, have them both bolted down.
    It cured the problem a friend and father in law's car that i sorted. Fluid level check as well. The cap will have level dip attached.
    Apr 2008
    murton seaham
    buy a insignia then you would know what problems are
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by tonyord View Post
    Not helpful!!! Lol
    Nov 2012
    Redcar
    haha tony think myne just wants scrapping now
    Apr 2008
    murton seaham
    Maybee ,see what they say when you get it back mate
  1. 1.8VVT No Power
    By Chris SRi in forum Engine & Drivetrain
    Last Post: 13th June 2015, 22:14
  2. Replies: 17
    Last Post: 11th March 2015, 00:55
  3. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  4. Replies: 0
    Last Post: 1st October 2012, 17:40
  5. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
vectra vvt power steering pump
