Results 1 to 10 of 17
Thread: Clicking from behind drivers headlamp
    Jan 2012
    Darlington
    Default Clicking from behind drivers headlamp
    Hi
    There's a clicking noise just started somewhere behind drivers side headlamp, it sounds like a relay constantly clicking does anyone know if there is one around there or any other ideas what it could be.
    Its the Sri turbo on a 54 plate
    Thanks....Andy
    Jan 2012
    Darlington
    Hi again clicking now getting faster its more of a buzz now lol car running fine tho
    Jan 2012
    Darlington
    Someone said it could be the fuel pump but don't think that would be behind the headlight
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    what engine is it, sri means nothing
    there is not much behind the drivers headlight though, you have the power steering pump below it, or do you think its coming from the engine itself but from that side/area
    Jan 2012
    Darlington
    Hi
    Its not from the engine its does it when is turned off, its the 2.0 petrol turbo
    Some possibilities
    The headlamp leveling motor might be stuck in the on position, so test this switch to see if the aim adjusts
    There is a control module on the mounting point for the Power Steering Pump, and is susceptible to water ingress and failure
    Apart from that, there isn't much else in that area
    You might have to switch the engine off and strip some parts to ascertain the source
    Jun 2009
    South Coast
    ok, same engine as mine.. you may want to check out your power steering pump but thats a bumper off job.. is the aircon switched off when you hear this.. BTW your fuel pump is in the petrol tank at the back of the car..
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 137000
    i was thinking The headlamp leveling motor might be stuck
    Jan 2012
    Darlington
    Bumper off doesn't sound good lol would that be a new pump needed then ? I've never used the head lamp leveler didn't know it had one, everyone who has heard it says it sounds electrical its like when ur battery is flat you turn the key and it clicks
    Andy
    Jan 2012
    Darlington
    That control module sounds possible what does it look like, is it easy to get to ? I'm a bit of a novice at this lol
  1. clicking from drivers wheel
    By steve19cdti in forum Vectra C / Signum Troubleshooting
    Last Post: 5th December 2011, 20:16
  2. Facelift drivers side SRI Headlamp
    By sri andy in forum Parts for sale
    Last Post: 30th November 2009, 23:09
  3. drivers door clicking
    By scotty6w in forum Bodywork & Interior
    Last Post: 28th September 2007, 16:34
vectra c headlight motor clicking
