Thread: lack of power after cleaning EGR
    Regular Member daz-b's Avatar
    Nov 2011
    grantham
    Vehicle : insignia sri vx line
    Trim : vx line
    Engine : 2.0 cdti 160
    Year : 2011
    Mileage : 57000
    confused lack of power after cleaning EGR
    Hi guys hope someone can help but decided to clean my EGR valve on my 2.2DTI today as it was in need of a deep clean, was running fine before i started but after its lacking its pulling power, the engine does seem to rev alot smoother but it doesn't feel right now, took it for a thrash to see if would sort its self with no success only going into limp mode for the first time in 6 month, forgot to mention i'v also cleaned the boost sensor on the inlet manifold.
    cheers.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    On the inlet manifold? Boost sensor is near the front, the one next to egr is maf sensor. I suggest u give that a clean too.
    Nov 2011
    grantham
    Trim : vx line
    Year : 2011
    Mileage : 57000
    cleaned this as this was also clogged up, i give the MAF a clean see what happens
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Check all connections.
    remove an refit egr to make sure. It maybe sticking. May also be worth pulling batt for half hour (ensuring you've got stereo code)
    Nov 2011
    grantham
    Trim : vx line
    Year : 2011
    Mileage : 57000
    i'll try that in the mornin, just been out and pulled the battery, cheers for the advise.
    Nov 2011
    grantham
    Trim : vx line
    Year : 2011
    Mileage : 57000
    solved my problem
    after routing around in the dark and now have frost bite i noticed a vac pipe had come off next to the vac pump, i obviously knocked it off when taking the boost pipe off, the cars running spot on now, anyway many thanks for everyone's advise.
  1. 1.9 120 Lack of power.
    By carling in forum Engine & Drivetrain
    Last Post: 29th January 2013, 19:25
  2. Lack of power...
    By lightfx in forum Engine & Drivetrain
    Last Post: 20th October 2010, 14:33
  3. lack of power
    By dods in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2010, 20:33
  4. lack of power
    By astratovectra in forum Engine & Drivetrain
    Last Post: 20th February 2010, 19:56
  5. Lack of power
    By reptar in forum Engine & Drivetrain
    Last Post: 20th November 2009, 20:00
