Thanks Thanks:  1
Likes Likes:  1
Results 1 to 10 of 19
Thread: gearbox oil change?
    Regular Member will-crowe's Avatar
    Jun 2012
    Norwich
    Default gearbox oil change?
    hi all, since having my vectra 1.9 cdti 150bhp i have noticed the gear change is not as slippery as my 55 plate vw or my dads. is there such a thing as replacing the gear box oil with a higher quality to give me a smoother transaction? as feels a bit rough when cold, could be better when warm also. not crunching or anything its just something that niggles me on my journeys
    Professional Trader oilman's Avatar
    Nov 2005
    Cornwall
    6 Post(s)
    Vehicle : Posche
    Trim : 928 S4
    Engine : 5.0
    Year : 1989
    Yes, a better oil can improve shifts. You need an MTF for the gearbox and I would go with the Redline MTL, Amsoil MTF or Fuchs Sintofluid.
    http://www.opieoils.co.uk/c-670-75w-80-75w-85-mtfs.aspx
    Tim
    oilmans website : www.opieoils.co.uk/
    e-mail : oilman@opieoils.co.uk
    tel : 01209 215164
    Regular Member ScottyV6's Avatar
    Feb 2011
    Worcester
    Is it the F40 box on yours. if so when you change the oil don't put the same amount as what the book recommends, only put in 2.2 litres which will equal 2.4 litres in the gearbox. This is the fix from Vauxhall and used with a lot of success with many members on here.
    Jun 2012
    Norwich
    Oh ok thanks will get it look at. Need to learn to do this myself lol but I think a mechanic might be in order this time as I wouldn't want a hot gear box
    Usually with age and mileage it is just the lubricating oil on the lever selector itself which has reached the end of its life
    I usually list that as an item to be attended to every fourth service, vastly improves it
    Equally, when this is attended to as part of a service there is nothing extra to pay
    Regular Member Beardy's Avatar
    Oct 2012
    Thetford
    Vehicle : Astra
    Engine : 1.7 CDTI
    Mileage : 110,000
    i have same prob with mine, wen cold its hard to get gears and get a crunch evey now and then, also wen warmed up it ok but not silky smooth.
    What bit do i need to lube? or just lube the whole linkage? ta
    Quote Originally Posted by Beardy View Post
    If you have the f40 gearbox then the stiff cold shifting is probably being caused by the synchronizers, or more specifically by too much oil pressure which prevents the synchros from working properly/efficiently hence the crunching. there is a fix whereby you drain the box and refill with a reduced quantity of oil. capacity is 3.2L but the vx fix recommends to only put in 2.2L.
    There is another problem with the f40 whereby the selector on the top of the box seizes and this causes the right left movement of the gear stick to become slow and stiff and not spring back to centre in neutral. the fix for this is not as well discussed on here but some have removed the selector, disassembled, cleaned and re-lubed and that cures that.
    Reducing oil volume only helped a little in my case. some also put molyslip additive in there which can help i believe though Im yet to try this.
    Aug 2016
    Croatia
    Vehicle : 1.9 CDTI
    Trim : Vectra
    I recently changed gearbox oil in F40. I used 75W90 oil, 2.2L and now during colder days I noticed stiff cold shifting from 1st to 2nd gear. I 75W90 oil grade correct?
    Nov 2005
    Cornwall
    6 Post(s)
    Vehicle : Posche
    Trim : 928 S4
    Engine : 5.0
    Year : 1989
    Hi
    It's a bit thick and you'd be better off with a 75w-80 and the best proven options are the Red Line MTL, Fuchs Sintofluid or Amsoil MTF. The Millers TRX 75w-80, Castrol Syntrans V-FE, Gulf Syngear FE and Motul Motylgear are good alternatives.
    Tim
    tel : 01209 215164
    Regular Member nikolat's Avatar
    Nov 2014
    Bosnia and Herzegovina
    Vehicle : SIGNUM 1.9 CDTI 16v (Z19DTH) 2005
    Trim : SIGNUM
    Mileage : 160000
    Same question. Can I use some other oil like 75W85 or 75W90???
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. M32 gearbox oil change??
    By shb1988 in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2013, 20:51
  3. F23 gearbox and oil change?
    By Deadman in forum Engine & Drivetrain
    Last Post: 12th December 2010, 18:16
vauxhall vectra 1.9 cdti gearbox oil change
how to change gearbox oil 2004 signum 1.9cdti
astra 1.9 cdti gearbox oil change where do you top it up
what is the gear oil for Opel vectral 2.2L
what is the of the gear oil I can use for my Opel vectra 2.2L
vectra c 1.9 gearbox oil how to change
how much gearbox oil does it take to fill a vectra c gearbox
vectra c gear box oil
