Thread: oops
    Regular Member jamiedvvt's Avatar
    Sep 2012
    Inverclyde
    Vehicle : Vauxhall Vectra
    Trim : Sri
    Engine : 1.8 vvt
    Default oops
    Think i may have been stung with one of those speed camera vans, I pulled out of my street on to the main road and turned left towards Kilmacolm doing about 33 (give or take) in a 30 zone , went up to my moms shop to drop off a few things and on the way back down i noticed the speed camera van was parked just down from my house. I did not see it on the way up luckily wasn't speeding coming home but was in a bit of a hurry to get up there, my own fault so will just have to wait and see if anything comes in through the post, really hope it wasn't there on the way up
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Today is Thursday, so you should know by Monday or tuesday. I got caught by a van 4 years ago, Tuesday night at 6pm, FPN was through the door the same Friday.
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    Well i'm hoping nothing lands on the door mat. i'm pretty sure it wasn't there on the way cos you cant miss the thing (wishful thinking)
    Oct 2012
    peterlee
    Dont most forces operate a 10 percent plus 1 policy ? As speedometer can be 10% out either way , sure for alot of forces you have to be doing 34 mph in 30 before they prosecute ! Could be lucky !
    [Ex]Admin Duncan's Avatar
    If you were doing an indicated 33 on your speedo then you won't have been doing 33 actual. Because a speedo is not allowed to under read by even 1 mph i.e. indicate 30 when you're actually doing 31, manufacturers generally set them to over read, and it's allowed to over read by up to 10%. So if you were doing an indicated 33 then it's going to be a couple of mph less actual so unless your area is operating a zero tolerance on speed then you shouldn't have anything to worry about.
    Quote Originally Posted by mutley-k666 View Post
    As speedometer can be 10% out either way...
    Not quite. Can only over read by up to 10%, but can't under read at all.
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    Well lets hope that its fine
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    Quote Originally Posted by jamiedvvt View Post
    is that a pun intended?
    hull
    indicated 32mph in my vec shows 30mph on the sat-nav.
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    Was meant to say hope its not a fine lol
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Had speed fine for 33mph, i asked if i have to pay etc, they let me off as its within range of 10% not more! So 10% of 30 is 3.33333333 lol so it'll be rounded up to nearest number meaning 3mph max over 30mph.
    It'll only capture by measuring at a distance to about 5-10 metres away from camera in van.
    If u're pulling away at a distance. Think you'll not get it. Depends how far away van was from u.
  1. Big oops or small oops? infor needed
    By davidmcd2002 in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2011, 17:44
  2. Oops
    By yessof in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2010, 06:45
  3. Oops
    By Sawyer Reynolds in forum The 'Off Topic' room
    Last Post: 17th April 2008, 20:00
  4. oops
    By Alec in forum Introduce yourself.
    Last Post: 12th January 2008, 02:11
  5. oops
    By John35 in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2007, 16:11
