Thread: 5th cam belt snap!
    Dec 2012
    bristol
    confused 5th cam belt snap!
    vectra 1900 diesel 2008 dtci. Iv had this problem 5 times in the last 2 years and twice had engine rebuilds. This being the second. The other times I could here the timing coming out of sync so stopped the engine. It always happens when the alternator belt snaps. The alternator belt deteriorates and becomes entwined with the cam belt which skips a few notches and ******s up the engine. Which is preceded with a few days of squeaking of the alt belt. Im a taxi driver so all faults come round very quickly. What can I replace to stop the alternator belt from squeaking and snapping?
    Full Member gixerjd's Avatar
    Dec 2011
    leeds
    Vehicle : vectra c
    Trim : vxr
    Engine : z28neh
    Mileage : 31000
    Quote Originally Posted by vauxhallvectra View Post
    check all the ancillaries on the belt are aligned right if not will cause the belt to ware out quicker than norm
    also if you a taxi driver doing high miles change the belt on every service there only a few quid extra on top of the service
    also check the tensioner is not worn
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    yeah cant help but think a little cash in preventative maintenance would save you the large bills, its about £12 for a new belt and fitted in 30 mins and a squirt of belt slip once every couple of weeks will help stop the belt from drying out and cracking too
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    Quote Originally Posted by gixerjd View Post
    Taxi drivers vary rarely have there cars serviced properly most only have what needs doing so that wouldn't work.
    Im sure if the belt was changed when the "squeeling" noise started you wouldn't be in this position.
    As has been said proventative maintenance would prove worthwhile
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Even for a taxi, five alternator belts in two years is incredibly high numbers. My cars only on it's second in 8 and a bit years, I appreciate the mileage difference is immense but even then.
    Are you actually fitting new belts each time or second hand ones?
  1. Quick snap
    By savage. in forum Quick Photo Album
    Last Post: 11th December 2009, 17:00
  2. this cold snap
    By dean_walsh2001 in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2009, 00:16
  3. Snap Decision - What do you do...
    By BigMan in forum General Chat
    Last Post: 20th July 2009, 14:11
  4. Replies: 31
    Last Post: 19th January 2008, 17:32
  5. Snap !!!!!!!!!!!!!!!
    By FIL 4822 in forum General Chat
    Last Post: 2nd December 2007, 23:33
