Thread: Does your car drift left? Help!
    May 2012
    UK
    Default Does your car drift left? Help!
    Hi all
    I recently got the front springs changed on my '06 VVT exclusiv because one had broken (I changed both). It was done by a main dealer but they had to use aftermarket springs as it was under a 3rd party warranty.
    Since then it seems to drift left - I can't make my mind up whether it is worse than before, I guess I didn't notice it before if it was doing it.
    The only thing that has changed is the springs, but apparently they are the correct model for my car (std suspension), the car sits right as far as I can tell and drives ok apart from this issue. The springs also look correct visually as far as I can see.
    If I'm on a decent stretch of motorway with very little apparent camber cruising at 70 in the left land and hold the wheel loosely it will drift left and be at the point of crossing into the hard shoulder after a count of between 5 and 10.
    Just after some feedback from other owners to see if this is normal?!
    If not, could springs cause this?!
    Feb 2011
    Selby
    To check whether it is a camber effect or not, try driving on the right hand side of a road (with plenty of visibility!) and see if it still drifts left. Other than that, go and have your wheel alignment checked.
    May 2012
    UK
    Quote Originally Posted by rich r View Post
    Hi, thanks. So if it didn't (or it pulled right) then this would be considered normal? I'm not very technical
    Apparently the garage checked the alignment and it's ok!
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Remember?? Road are not flat! It'll be dipped left slope for rain to part away! If u're pulling right then alignments' off!
    Check tyre pressure, bounce the front and rear to see it bounces back up right. Softer or firmer differences can affect.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    When was the last time the brakes were stripped and cleaned?
    May 2012
    UK
    Quote Originally Posted by John IS3 View Post
    Hi, I got them done about 3 months ago when I had new pads fitted, I did jack the car up and everything seems to be spinning freely
    Regular Member allyp's Avatar
    Aug 2010
    aberdeen
    Think all cars are meant to pull slightly left
    Regular Member tiimi's Avatar
    Sep 2012
    anglesey, uk
    Quote Originally Posted by allyp View Post
    yeah, i heard a few times its a safety feature of all cars, vans and lorries ect. stop you drifting into oncoming traffic ie. falling asleep at wheel. and also, have you noticed how a massive majority of crashed vehicles with the driver falliing asleep at the wheel, the cars allways on the same side !
    Aug 2010
    Leeds
    Swap the front wheels over left to right then take it for a drive, tyres can make it pull do you have any worn more than the other?
    May 2011
    luton
    My car did the eaxct same after i got my springs done got it allignd n still pulled to the left changed both my front tyres and hey presto its alll goood again
  1. r33 drift car :)
    By vectraturbocal in forum Non Vectra C/Signum Album
    Last Post: 3rd September 2013, 19:07
  2. I seriously need a drift car..............classic lol
    By signum_rob in forum General Motoring Chat
    Last Post: 11th June 2012, 00:25
  3. Graffiti Drift Car.
    By weverall in forum General Motoring Chat
    Last Post: 4th February 2012, 22:24
  4. How to drift on 2 wheels!!!!!
    By BIG NEIL in forum The 'Off Topic' room
    Last Post: 6th July 2008, 23:45
  5. How NOT to drift
    By muffking in forum Comedy & Humour
    Last Post: 21st January 2007, 20:02
