Thread: Crank Sensor
    Aug 2011
    Bristol
    Default Crank Sensor
    Seem to be having codes stored for crank sensor.
    I am going to change it but is there anything I need to know for changing it?
    Does it need to be programmed to ECU or something like that?
    Or is it simple out with the old and in with the new?
    Dec 2011
    Seaham
    I beleive it is just a sensor and a straight swap.
    Aug 2011
    Bristol
    Thanks. Not normal to see an easy job but great news
    Agreed, just remove the old one and replace it with the new one
    However, my recommendation is to also replace the camshaft sensor at the same time, as these two sensors rely on each other and their life span is about the same
    Aug 2011
    Bristol
    Well I take that advice as great but the camshaft sensor is 3 times more than the crank.
    With all the rest of the work I am paying for that's a little tight to squeeze out.
    Will do that one after crimbo and at least I know now to change it anyway.
    Still thanks
  1. Where is the crank sensor 1.9 cdti 8v
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2013, 05:46
  2. crank shaft sensor
    By dr1v3r in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2012, 19:54
  3. P0340 - could it be crank sensor?
    By rich r in forum Engine & Drivetrain
    Last Post: 25th December 2011, 19:00
  4. help the crank shaft sensor needs changing
    By andyman201 in forum Engine & Drivetrain
    Last Post: 16th October 2009, 01:25
  5. Crank Sensor location cdti 150
    By kirkyoke in forum Engine & Drivetrain
    Last Post: 7th September 2009, 19:10
