Thread: Shiny new inlet manifold is on!
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    Default Shiny new inlet manifold is on!
    Got my car back last night with a brand spanking new manifold so now I have shiny clean new swirl flaps
    It had it's MOT at the same time so I thought it's the perfect time to blank my EGR, so I went about fitting my blank tonight, got the bolts out & pulled the EGR pipe down... then the flipping gasket fell deep into the depths of the bay- ********!
    Fitted the blank, fitted my DT UK green box & I'm in love. But now the EGR restrictor is on (Went for the one with 1 single hole in the middle) I get a wooshing type noise (Bit like a boost leak) when I rev it, easily hear it on idle too..
    Now is this the EGR restriction 'hole' making this noise, or the fact it's not got a gasket between the egr pipe/blank/egr? (A single metal gasket fell out, couldnt see any other gaskets)
    & if it is because I dont have a gasket, is this gonna be an issue?
    Cheers!
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    it wont sound the same due to not having the gunk in it but you will need that gasket
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Do you need a gasket either side of the Blanking Plate?
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    I'll order a couple of gaskets then. I've read there's supposed to be a gasket either side? Like I say, only 1 single metal one fell out, unless the other stayed in & was stuck to the EGR it's self.
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    I'd be tempted to fit a full blanking plate and get the egr deleted from the ecu if you want to keep that inlet manifold shiney. With the hole in it you will still get a load of crap going through it over time.
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    The blanking plate replaces the metal gasket so you don't need to order any
    hth
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    So the new 'whooshing' noise/sucking noise is just the fact theres the small hole in the blanking plate?
    Cheers!
  1. Inlet manifold
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2011, 19:50
  2. New inlet manifold,,,,new car !!!!
    By collyb in forum Engine & Drivetrain
    Last Post: 15th April 2011, 13:10
  3. inlet manifold !
    By si_sri in forum Engine & Drivetrain
    Last Post: 20th November 2009, 22:06
  4. Inlet Manifold
    By topcat850 in forum Engine & Drivetrain
    Last Post: 13th November 2009, 14:33
