Results 1 to 10 of 13
Thread: drain coolant without taking bumper off
    Regular Member andy_richmond's Avatar
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Default drain coolant without taking bumper off
    want to change the stat and change the coolant, is there an easy way to drain it without taking the bumper off. its a 2.2 dti 04 plate, can i get my hand in to the drain tap, if there is one
    East Midlands
    Yer mate you dont need to take the front bumper off,the drain is bottom left as you look at the car,get hold of some clear tubing and stick it on the outlet and lead into a bowl or something or just let it run out into a drain nearby
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    so just reach my hand in past the rad on the drivers side, is it a tap, screw??? any pics anyone, ive googled like mad but cant find it
    East Midlands
    Yer there's a tap there mate,if like mine its seized, spray some dub dee on it and leave it a while then attack with pliers,its right at the bottom left looking at it from the front have a feel under there ,you'll find it.
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    cheers mate
    East Midlands
    Yer there's a tap there mate,if like mine its seized, spray some dub dee on it and leave it a while then attack with pliers,its right at the bottom left looking at it from the front have a feel under there ,you'll find it.It where the arrows are on the pic bud. Double post as did pic after.
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Thanks mate. Il give it a go tomorrow
    11 Post(s)
    IIRC, you have to pull it as you undo it. The drain plug won't come right out, btw.
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    hmm, the dti is packed under there, i may have to take out the lower grill to get my hand in there, intercooler and aircon pipes all in the way, or go for the dreaded bumper removal
    Feb 2011
    Selby
    If you can't get the tap to undo (don't force it, it's only plastic!), then just undo the bottom radiator hose. Stick a washing up bowl underneath as a the coolant will tend to come out and run off several things rather than a nice single stream.
  1. 1.9CDTI (120) - Coolant drain point
    By snapsnap in forum Engine & Drivetrain
    Last Post: 27th May 2012, 11:56
  2. Drain Plug - Coolant
    Last Post: 22nd June 2009, 13:53
  3. Anyone tell me how 2 drain the coolant?????
    By frazejax in forum Engine & Drivetrain
    Last Post: 25th August 2008, 09:04
  4. taking off rear bumper
    By vectragsi3.2 in forum Bodywork & Interior
    Last Post: 8th April 2008, 13:06
  5. What's the easiest way to drain the coolant on the GSi ?
    By muffking in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2006, 19:40
vectra c radiator coolant bumper
