Results 1 to 2 of 2
Thread: water pump change
    Aug 2011
    Bristol
    Default water pump change
    Having my pump changed next week.
    When I spoke about it with someone they said the camshaft cog would need to come off and timing chain cover.
    I have looked through Haynes and it says notihng about this stuff coming off.
    I was going to buy cam bolt and seal if it was coming off.
    If it does not state in Haynes should I buy this stuff?
    Is there anything I do need to buy which must be used once?
    I am supplying parts this is why I need to check.
    It's a 2.2 direct Z22YH
    Aug 2011
    Bristol
    Confirmed.
    Timing and crank bolt does not need to be removed to change water pump.
    Yay
  1. Hesitant after water pump change
    By GCusdin in forum Engine & Drivetrain
    Last Post: 28th December 2012, 13:17
  2. Did cam belt and water pump change
    By dontsnatch in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2012, 09:57
  3. Cambelt and water pump change
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 1st August 2011, 14:39
  4. Cambelt kit & water pump change
    By Pete1nlancs in forum Engine & Drivetrain
    Last Post: 30th July 2010, 19:07
  5. Cam Belt & Water Pump change...
    By si_sri in forum Engine & Drivetrain
    Last Post: 27th June 2010, 21:48
z22yh how change waterpump
changing water pump on vectra c
