Thread: help needed please
    Regular Member neil52's Avatar
    Oct 2012
    leeds
    Default help needed please
    signum 2003 2.2dti. im trying to replace my starter motor but im stuck. ive taken off all connection and undone 3 big bolts from right hand side but it just wont budge am i missing anything else that holds it in place.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Nope they are tight as F**** i had to get a small crowbar and praise it out wait till you try put the new one back in that is a pain
    Oct 2012
    leeds
    ive just notice there is a type of bracket on the left side with 2 small nuts does this have to come off or is it attached to the starter motor
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    ooops i miss read that i thought alternator when i did my starter sure it was 3 bolts and it fell out but that was on 1.9cdti vec.
    Oct 2012
    leeds
    ok cheers will struggle on ordered a manual but hasnt turned up
    Nottinghamshire
    Removal steps not including removing undertray or exhaust:
    Release upper part of starter - 1x bolt
    Detach starter heat shield - 2x bolt, 1x nut
    Detach oil pressure switch wiring harness plug
    Detach alternator wiring trough - 3x bolts
    Release exhaust manifold support - 2x bolts
    Detach 3x starter cables
    Remove starter - remove lower bolt, press alternator wiring trough up & remove starter downwards
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  5. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
