Thread: Headlight alligning fix?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Headlight alligning fix?
    Ok, my wife's dad's 2nd vectra c sri 2008 have a headlight that dips the light at the floor. Nearside.
    Drivers side headlight is correctly positioned, i tried hex to bring up the nearside but not moving at all, which comes to conclusion that its dislodged the tooth mech for adjusting.
    Anyone know how to go about this? Fix without taking headlight out and work on it as in fix while still attached to car??
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Does it level from inside the car.
    TBH i think this will be a light out to fix it mine was the same one of the we yellow turny things had fell off so when i was trying to turn it nothing moved.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Its the thing u turn it up/down that isnt working, the left/right bit is missing.
    He most likely get whole light replaced, car sold to brother in law on the cheap!! Lol
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Likely the levelling motor has come detached?
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    its not hard to get the headlight out, just a good few screws. take the screws out down the wheel arch, then along the front where the grill is and bend the bumper down to expose the bottom headlight fixing screw and undo it and it just falls out once u have undone the other 2 at the top easy peasy.
    oh meant to say, the bumper just unclips at the side dont be afraid to give it a good pull.
    Regular Member se4's Avatar
    Aug 2010
    wales
    Make sure the bulb is fitted correctly first!!
    Possible it's not 'clicked' in place properly
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by se4 View Post
    That's what I was going to say done an Astra on Friday with the same problem and whoever had fitted the bulb in had not pushed it home properly causing the beam to point down to the road and give very poor light
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by rozzer2006 View Post
    Tip for you, as you unscrew the top wheel arch liner screw push the screw into the hole. This screw works a clamp that tightens on the bumper as you tighten the screw. Just pulling it will wreck the tabs on the bumper eventually
  1. headlight help pleaSE
    By jimmywhu in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2012, 17:50
  2. Headlight cap
    By aerodynamic18 in forum Electrical & ICE (including SatNav)
    Last Post: 19th February 2012, 22:46
  3. Headlight
    By mageamind1979 in forum Bodywork & Interior
    Last Post: 7th January 2012, 21:08
  4. DIY headlight mod day!!!!!
    By bertbuckie1 in forum Styling
    Last Post: 4th January 2011, 00:07
