Thread: HELP! Automatic gearbox problems
    Portugal
    Default HELP! Automatic gearbox problems
    Hello
    Iím owner of a OPEL VECTRA C 2.0 Dti, 5 gears automatic gearbox, Iíve purchased it 2 years ago and until now I had no troubles. One month ago the car had the following problem, it signaled a fault on the desktop (tool symbol) and the gearbox in automatic mode blocked on the fifth gear. In order to drive Iíve changed into sequential mode but the gears available were only the second and the fifth, all the others were not possible to be selected. Iíve went to the OPEL official workshop it stayed there for one week and their diagnosis was a faulty gearbox ECU, the repair cost me 1200 Euros, ok by me if it had solved the problem. Two weeks later Iíve got the same problem in the of traffic jam it was quite annoying to drive with only two gears available. I went back to the same official OPEL workshop and the car stayed there for 2 weeks ( :-( AGAIN ) and they told me that the problem was on the gearbox itself, the price for the new gearbox is 5100 Euros times 21% taxes, plus the handwork. It is quite a punch in my wallet.
    My questions are:
    Is there anybody out there with the same problem?
    If so how did you solved the problem?
    Can the problem be from another source besides the gearbox (electronics)?
    Do you think the guys in the workshop are incompetents and canít find the truth source of the problem?
    Iíve read this ďOn the 1.9 diesels, the wiring harness can rub bare on the transmission casing causing a short circuit that blows the main fuse leaving the car completely disabled. There may be a recall or at least a tsb to check for this.Ē on
    <http://www.honestjohn.co.uk/carbycar/index.htm?p_make=VAU&h_make=VAU&p_model=%20526 > can this be the source of the problem and the stupid mechanics wont find it?
    HELP!!!
    Just a couple of ideas..
    either the clutch bands have worn out or
    the gear selector switch has worn on it's contacts (it's on the top of the gearbox) or
    the valve pack within the gearbox has a fault.
    and do you have any funny colour coolant in the engine.. our old vectra had a leak between the radiator and the gearbox that meant we had to have a new gearbox.. all the engine coolant got into the gearbox.
    Portugal
    Well the mechanic said something about the gearbox valves, he said he reprogrammed the valves timing to see problem was solved by this way, but seems like it didnít and he said the solution was a new gearbox, which for me is quite expensive (plus the new gearbox ECU from the first repair).
    Nicking Ya Dinner.
    Breakers yard, then get shot of it.
    May 2007
    Ilford
    Hi - I have got EXACTLY the same problem.
    Regular Member Sundance's Avatar
    Scotland
    There have been problems with moisture in the input and output speed sensors connections, i had one that would lose all gears except 2 and 5, also had codes for both sensors, removed and cleaned both sensors, refitted and all was ok for a couple of weeks then the fault returned. tech 2 showed a fault with the speed output sensor. Renewed it and its been fine since.
    This was on the AF23/33 gearbox.
  1. Automatic gearbox, recommended?
    By astradriver in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2013, 19:09
  2. Vectra C 1.9 CDTI Automatic Problems - Engine & Gearbox
    By johal87 in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2012, 23:37
  3. Automatic Gearbox
    By delboy2028 in forum Engine & Drivetrain
    Last Post: 1st March 2011, 16:28
  4. Signum 2.2 dti automatic gearbox
    By apacheenzo in forum Engine & Drivetrain
    Last Post: 2nd April 2010, 21:06
  5. Automatic Gearbox problem
    By tomhrb in forum Troubleshooting
    Last Post: 4th June 2009, 16:54
