Thread: 1.9 CDi design (150 Fuel Filter Removal Tools
    Dec 2012
    Newcastle
    Default 1.9 CDi design (150 Fuel Filter Removal Tools
    Are having specialist tools esential to changing my fuel filter?
    Nov 2010
    East Midlands
    Trim : design
    Welcome to the forum - I think there is a special tool for doing most jobs on Vectra's but you don't need any to change the filter, the large ring on top of the filter housing has to be unscrewed and one of them rubber strap wrenches can be useful for that. The fuel pipe clips have to be released and this can be done using two small screwdrivers to push the clips in and release the pipe. Be careful with the housing as it is quite fragile and can be easily damaged especially the fuel pipe connectors and the whole housing is made of a brittle plastic that won't take too much hammer. This should help http://www.vectra-c.com/forum/showth...34#post1301434
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    I used a towel and strength to unscrew and screw back the same strength of tightness, grab all fuel in there into a clean bowl or some sort. So u can safety throw away the fuel in there effectually keeping new filter clean as possible with fresh fuel!
    Welcome to the good helpful forum! :-)
    Nov 2009
    Warrington
    i know its do able with out the proper vx tools but does anyone know parts numbers etc for if i was to get the correct tools, filter housing removal tool and fuel line tool?? im wanting to do this but dont fancy breaking anything lol
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    I used a cheap oil filter removal tool, the chain type one, about £5 from halfords or any auto parts shop. I carefully wedged the filter in the corner of a step (did not have a vice then) with one end projecting over the step so I can use the oil filter tool to undo it. a bit tight but it came off after a bit of swearing and blinding. But easier to use a vice and oil filter tool.
    Nov 2009
    Warrington
    Quote Originally Posted by plasma View Post
    Good man cheers.
  1. Fuel Filter Removal
    By andsaw in forum Engine & Drivetrain
    Last Post: 5th January 2013, 21:00
  2. Fuel filter housing removal - 1.9CDTi
    By AlexGSi2000 in forum Engine & Drivetrain
    Last Post: 7th July 2012, 17:08
  3. CDTI Fuel filter removal tool
    By v33tra in forum Engine & Drivetrain
    Last Post: 8th February 2012, 22:34
  4. Fuel Filter removal
    By hefilump in forum Engine & Drivetrain
    Last Post: 21st July 2010, 23:00
  5. Fuel filter removal?
    By Ian T in forum Engine & Drivetrain
    Last Post: 2nd May 2008, 22:33
