Results 1 to 10 of 18
Thread: CDTI 150 - Serviced so now what?
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Default CDTI 150 - Serviced so now what?
    Have very limited knowledge of this engine, going to get various cleaning products for sensors and connectors etc, just for piece if mind...
    So where to start, EGR is blanked so shouldn't need a clean, boost solenoid pipes are new, 3rd injector connector already replaced so...
    What else could do with doing? and there location, pics if poss please
    Also what fuel additives are best for cleaning etc? Might even try some 2 stroke after...
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Taken the inlet manifold of and clean that now that's a job and a half lol take the intercooler pipes off and clean them out mate and yes I no am sad lol
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    I'll Prob do the manifold when the rads need to come out
    Was thinking small scale for now lol
    Sep 2010
    Forte, works very well. I put the additive in at quarter tank rather than full tank to give a good clean out.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    The EGR has been blanked for virtually the whole time since the manifold was replaced (unless the blank was removed of course).
    Fuel filter is a good thing to replace and often gets overlooked.
    It always used to have Millers Diesel Power Sport 4 in the tank which did make a difference, be worth using that IMO.
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Yes should still be blanked, although the spanner light no longer stays lit so will have to check...
    Did you add both? And did one you fit have the holes or not?
    Remember finding a plate in the seat pockets, I gave it away as thought spare, just text Josh now to make sure he didn't remove it...
    scottish region
    The boost sensor next to egr valve
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by leemarksmith View Post
    I did have a eBay one that I gave him when I sold it to him, it was probably that one.
    It just had the manifold one with no holes.
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Oh good... panicked then, hopefully its the spare I found (no holes) in the car I gave away then lol...
    But no constant light on has got me thinking, spanner light comes on then off once started, but the last MOT might have made him remove it maybe...
    Lancashire
    Trim : XP1
    Mileage : 66000
    Yeah, with the work its had done recently, wouldn't surprise me if they have removed it. You should be able to check by looking around the seal of the EGR and manifold, the plate should be noticeable.
  1. Un-serviced....
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2012, 17:50
  2. never been serviced????
    By rob warrington in forum The 'Off Topic' room
    Last Post: 3rd June 2010, 14:00
  3. Serviced today, 1.9 cdti (150) Sump plug
    By robblue2x in forum Engine & Drivetrain
    Last Post: 6th September 2009, 12:08
  4. Where do you get your car serviced?
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2007, 23:54
  5. Just been serviced!
    By Flyingkiwi in forum General Chat
    Last Post: 16th June 2007, 19:15
