Results 1 to 10 of 15
Thread: z18xer knocking noise
    Regular Member jamiedvvt's Avatar
    Sep 2012
    Inverclyde
    Vehicle : Vauxhall Vectra
    Trim : Sri
    Engine : 1.8 vvt
    Default z18xer knocking noise
    Noticed a knocking noise coming from the engine when it is warm and it only does it every few seconds oil and filter was changed last month 5/30 fully syn oil and genuine filter also had to change the exhaust cam solenoid and took the filters off the solenoid no loss in power at all engine is sweet other than the noise 77k on the clock. Is this something i should be worried about ?
    Dec 2011
    Seaham
    Check for loose or broken engine mounts, is the exhaust loose? Bit hard to diagnose as you are not very specific about where the knock is coming from on the engine.
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    Have checked engine mounts they look fine, gave the engine a rock and seems to be fine it's hard to tell where the noise is coming from as it only last about a second then goes away for a few seconds seems fine when cold, only seem to notice it when the engine is warm and the exhaust is fine will try and have another listen today
    Dec 2011
    Seaham
    Do you notice a drop in revs when the knocking occurs?
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    No mate no drop in revs, its sounds more near the inlet manifold than anywhere else cant hear it when the engine is being revved, engine sounds sweet tbh just that annoying knocking sounds now and again but can't hear it from inside the car, think something could be loose near the manifold?
    Regular Member VVT-i-MATT's Avatar
    Feb 2012
    Calne UK
    Quote Originally Posted by jamiedvvt View Post
    Mine does this also has been doing it for about 2 months, but it's very faint and hasn't gotten any worse.
    I Think it might be the Cam Gears, but the engine is fine, and still runs sweet. I'm blaming the cold weather.
    What filters did you remove from the Solenoid?
    Matt
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    Yeah im putting it down to the cold weather as it was fine before the weather turned so cold i removed the filters from the cam solenoids the 2 orange ones and the black one at the end of the solenoid, maybe needs slighty thicker oil as its running on 5/30 fully syn
    VIP-Member antowens's Avatar
    Dec 2011
    liverpool
    mine makes tapping noise constantly done all i can full service, cam solenoid filers so on but still taps
    Sep 2012
    Inverclyde
    Trim : Sri
    Engine : 1.8 vvt
    Have had a good listen to it today and still can't pin point where the noise is coming from, nothing seems loose on the engine, but it sounds like the cold start knocking noise but the car is warm and the oil level is spot on, i think i'm worrying to much because the car drives spot on
    Feb 2012
    Calne UK
    Remove the top pulley cover, my noise is coming from the exhaust pulley.
    Goes away though after a run when I use the VVT. No good on slow runs, as the oil doesn't really get into the pulleys.
    Matt
  1. Z18XER (1.8VVT) Cam Pulley Noise
    By VVT-i-MATT in forum Engine & Drivetrain
    Last Post: 3rd November 2012, 21:46
  2. Knocking noise
    By The boy in forum Suspension, Wheels & Brakes
    Last Post: 3rd July 2012, 13:02
  3. knocking noise
    By chrissri82 in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 17:17
  4. Knocking noise...
    By Gripper in forum General Chat
    Last Post: 9th September 2009, 08:12
  5. Knocking noise
    By Triple Trouble in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2006, 11:47
vectra 1.8 vvt tapping
vectra c knocking noise exhaust
signum z18xer noisy
