Results 1 to 10 of 17
Thread: limp mode,cutting out,no turbo
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default limp mode,cutting out,no turbo
    Hey guys,
    Ive got a problem that only seesm to happen when its cold.
    Today i started the car and after about 5 seconds of ticking over it cut out.I then restarted and reversed about 10 feet and it cut out again.It happened again and this time the glow plug light illuminated and stayed on untill i started the car again.It cut out again and this time the spanner light came on and i had no turbo,i could hear it spooling up but it just wouldnt work.
    I drive about 10 miles untill i got to a garage(with the spanner light on) and plugged in my code reader but no codes came up.I thin switched off the car and started it and everything was fine.
    It definatly cold weather related as i had the same last year but not as bad.
    Has anybody got any ideas what it would be?
    I thought it could be dodgey glow plugs but they are only used on start up....i believe?? or maybe MAP sensor?
    Regular Member UltraVec's Avatar
    Jun 2011
    Dublin
    I had a problem with limp home mode coming on a good while back, wasn't to do with the cold but the engine rocking n vibrating caused injector sensor #3 to rub off the top cover and become loose which tripped the limp mode on. Engine might be vibrating more in the cold. Worth a quick check at least.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    I have slight alike issue. Been looking up on google. Many people have similar issue as me and you.
    Aug 2011
    Basingstoke
    Trim : SRI
    Thanks mate will check in the morning but im pretty sure it isnt the 3rd injector as theres no missfire or lumpy idle.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Check my recent thread i just added new post. It might be like your issue??
    Aug 2011
    Basingstoke
    Trim : SRI
    Ive just had a google search about glow plugs and aparently they are used for a few mins after the car is started and just just on start up like i was lead to believe so that would tie in with the car running fine after a couple of mins of driving
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Borrowed from a forum from vauxhall owners just for an sample
    Well light back on today under hard acceleration in 3rd gear got it to garage with light still on and they got a fault code this time. P0105. Map sensor abeiant pressure sensor. He said it's a common fault that be solved by cleaning boost pipes and manifold pressure sensor. But to be honest I've tested the car and under normal driving it's fine I can make the eml come on only if I take it right up to it's rev limit in 3rd or 4th and that said the garage av suggested to leave it as it's not a serious fault because it was the eml would stay on constantly.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by justin32 View Post
    Not glowplugs for sure. U'll get a slight misfire at start up.
    Aug 2011
    Basingstoke
    Trim : SRI
    Quote Originally Posted by Humourbash View Post
    Sound like you need a new MAP sensor,its also called the boost sensor aswell.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Not my post. Copied the post from vxon, i might need cleaning map sensor as well but where is it at? Next to egr? Bolted on with one screw right?
  1. Can limp home mode correct itsself? 3.0 turbo diesel
    By malk in forum Vectra C / Signum Troubleshooting
    Last Post: 15th August 2012, 06:52
  2. 1.9 CDTI Turbo Whine and ECM02345a spanner light + limp mode
    By wakey1512 in forum Engine & Drivetrain
    Last Post: 4th August 2012, 20:18
  3. No turbo, no warnings, no limp mode, but only happened once??
    By Ian-Highlander in forum Engine & Drivetrain
    Last Post: 30th August 2011, 16:13
  4. (2.2DTI SRI)‘LIMP HOME MODE’ icon. Turbo stops working!
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2011, 15:03
  5. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
vectrac.com vectra cdti limp mode when cold www.vectra-c.com
turbo cuts on vectra c 1.9cdti
vauxhall vectra diesel limp mode over heats and cuts out
z19dth no turbo
