Results 1 to 10 of 17
Thread: Intermittent rattle on idle???????????????
    Regular Member will-crowe's Avatar
    Jun 2012
    Norwich
    Default Intermittent rattle on idle???????????????
    AFTER READING A FEW POSTS ON HERE IM SLIGHTLY WORRIED LOL
    1.9 CDTI 150BHP ENGINE
    on idle theres a intermittent rattling sound. easiest way to explain is it seems the engine has 2 tones. for 2-3 seconds it ticks over then the next 2-3 seconds it ticks over and rattles like somethings loose, does this when cold. not noticed when warm but cant rule it out. its under warrenty by one month and dont want to ignore it to be something majorly expensive
    the car has done 72,000 miles
    please help
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    I had an issue with the coolant expansion bottle being a little loose for a while, causing a rattle noise, it was louder in the car than out. Have you tried to listen under the bonnet?
    If its the DMF it should be louder from around the passenger side wheel arch.
    newport
    not something simple like a loose heatshield is it?
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    DMF
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    my dmf (dual mass flywheel) did the same would come and go, it used to disappear when pressing the clutch in.
    Jul 2011
    UK
    Year : 06
    Radiator mount
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Sounds like DMF, when they first start to go they do it intermittent when cold, but don't appear to when warm.
    Best way to check have the foot on clutch when cold and see if it stops, if it does, its the DMF.
    Jun 2012
    Norwich
    ok cheers for the help i will try it in the morning and report back
    Jun 2012
    Norwich
    just went out and checked but was still slightly warm, no noise, but its defo there when cold. would i not have anymore symptoms? like clutch slipping, how long would someone say roughly it has left if its making a noise. its done 72000 miles
    Regular Member Craig1985's Avatar
    harwich essex
    Mesh on flex pipe??? That's where mine was
  1. 1.9CDTI 120 - Rattle on idle (NOT a DMF problem!)
    By snapsnap in forum Engine & Drivetrain
    Last Post: 22nd May 2013, 13:11
  2. 2.0T rattle at idle
    By GoldenWonder in forum Engine & Drivetrain
    Last Post: 22nd September 2012, 12:01
  3. Rattle on idle, dreaded DMF
    By Bjornatron in forum Engine & Drivetrain
    Last Post: 1st March 2012, 11:47
  4. Rattle clunking noise when revs drop to idle
    By pugs,signum in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd October 2009, 08:08
  5. Replies: 4
    Last Post: 31st July 2008, 15:29
Vectra c rattle idle
https:www.vectra-c.comforumshowthread.php177360-Intermittent-rattle-on-idle
vectra c rattle when idle
vauxhall vectra rattling noise when idling
idle rattle vectra c 110kw
vectra bottle rattle
vauxhall zafira engine rattle when idling
