Results 1 to 2 of 2
Thread: Climate control problem
    Dec 2012
    Banbury
    Default Climate control problem
    Didn't know where to post as I'm new
    my problem is nothing on the climate control panel works I have no cold or warm heat and no buttons light up ?
    Anyone have any ideas
    Nottinghamshire
    Have you checked the fuses for the climate control system? Refer to the handbook to find out which ones and bear in mind there are 3 fuse boxes.
    If you have climate control (rather than aircon) you'll have the temperatures - and other settings - across the bottom of the the screen. Are these there or is the bottom of the screen blank?
    Pop the climate control panel out and check the 2 wiring plugs on the back are secure. Maybe take them off and apply some electrical contact cleaner. To get the panel out, first pull out the cubbyhole underneath it then put your hands in and ease out the climate control unit the same way. You can also pop it out by pulling on the dials at each side of it but I wouldn't recommend it in case be break them.
  1. Climate control problem help!
    By CallumHill in forum Vectra C / Signum Troubleshooting
    Last Post: 18th December 2012, 23:20
  2. Air Con / Climate Control problem
    By itsmehere in forum Vectra C / Signum Troubleshooting
    Last Post: 28th May 2012, 21:33
  3. Climate control problem
    By POOL MAN in forum Vectra C / Signum Troubleshooting
    Last Post: 11th June 2009, 09:00
  4. Another climate control problem
    By 24vElite in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2008, 21:08
  5. Climate Control problem
    By bnam in forum Electrical & ICE (including SatNav)
    Last Post: 17th July 2007, 14:09
